Autotrans will not shift when floored! help please! - JeepForum.com
post #1 of 4 Old 09-15-2009, 06:15 AM Thread Starter
jh1328
Recently, I have been experiencing that "rattle" that we all know
happens at idle in a jeep. I started noticing it a little more, and some
wierd sounds in reverse, but no huge deal. Today, I was getting on to
a ramp on my way to work, didnt even floor it completely, and my
tach went pretty high, to about 4 or 5, but would not shift. As I said,
I have the auto trans, which has always been decent for me, but not
today. It kept revving, so I layed off the gas while the check engine light
blinked on and off repeatedly. It eventually went off and the jeep shifted
fine the rest of the way. Anyone else ever have this problem or know what
it could be?
-Josh
2004 Rubicon
jh1328 is offline
post #2 of 4 Old 09-15-2009, 06:32 AM
tavic
2010 JK Wrangler
Is your trans fluid full?
tavic is offline
post #3 of 4 Old 09-15-2009, 06:34 AM
Alexia
Alexia's Avatar
Go out to the Jeep, put the key in and turn the key to ON, then OFF, ON, OFF, and then ON fairly quickly. The odometer will display the error codes which you should write down and bring back to post here if any.
Sounds like the transmission was stuck in second gear which is the default gear when the transmission has an issue.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #4 of 4 Old 09-15-2009, 06:56 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2 on read code.
also make sure your fluid is full. the 42RLE auto is picky about getting its filters and fluid changed every 30k.
also you often need to completely let off the gas to get the 42RLE to shift out of 2nd when pulling onto the highway in 4k range, then it will drop right into OD unless you have the OD OFF button engaged.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
When adjusting Autotrans links... few questions opticalwaveguy TJ Wrangler Technical Forum 13 01-20-2012 05:09 PM
mc2100 autotrans bracket DonAltman3 YJ Wrangler Technical Forum 4 10-09-2009 02:09 PM
TJ starts but hesistates when floored Evian TJ Wrangler Technical Forum 8 02-03-2008 06:23 PM
Slight hesitation when floored Supertau TJ Wrangler Technical Forum 10 12-29-2007 11:46 AM
so the sahara turned 30K autotrans oil change? zband TJ Wrangler Technical Forum 7 07-26-2005 09:12 PM
