Automatic transmission shifter cable - JeepForum.com
post #1 of 24 Old 03-15-2010, 06:41 AM Thread Starter
Zen
Last night I pulled into the driveway put the Jeep in park to open the garage door and when I went to pull into the garage the Jeep wouldn't come out of park. The shifter moved freely. Not knowing for sure what gear the transmission was in I chocked the wheels and climbed under for a look-see.
The shifter cable is not conected to the transmission any longer. The transmission is in park, and I found a couple of plastic pieces under the Jeep that look like a retainer clip that snaps into the eyelet on the cable.
Can I buy a replacement retaining clip? Are there any special MOPAR tools I need to install it. My FSM does not mention it, but only mentions replacement of the entire shifter cable.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #2 of 24 Old 03-15-2010, 09:18 AM Thread Starter
Zen
Stealership says they only sell the cable, not just the retainer.
Anyone replaced the cable on a full console TJ? Any tips/tricks?
-Stick, splash one!
Zen is offline
post #3 of 24 Old 03-15-2010, 09:40 AM
ElJaynocibuR
I had the same thing happen. I think the cable cost me around 45 dollars. It was very easy to install. Lift up the coin tray towards the front of your console and I believe there is a 10mm bolt there. (I could be wrong though it's been awhile). I think it nay have taken 15 minutes from start to finish. You shouldn't have a problem with it.
2006 LJ Rubicon=4" lift, 305/70/16 Mickey T.'s MTZs, etc...
ElJaynocibuR is offline
post #4 of 24 Old 03-15-2010, 10:08 AM Thread Starter
Zen
Thanks!
10char
-Stick, splash one!
Zen is offline
post #5 of 24 Old 03-15-2010, 10:38 AM
BubbaGoose
While crawling around under mine,
I noticed mine is held on with two cable ties.
Been like that since the PO I guess
I have had it for 5k and 9 months.
BubbaGoose is offline
post #6 of 24 Old 03-15-2010, 10:53 AM
element54
element54's Avatar
Mine is also held on by zip ties and it has been like this for over a year now. There is a writeup somewhere the describes installing a bolt where the plastic POS came out. I'll try to find it and post back.
And I wouldn't wast my money on a OEM replacement since it failed within 3 yrs.
Here is the writeup.
http://www.jeepforum.com/forum/f9/05...ailure-600665/
Why is there so much space down here?
element54 is offline
post #7 of 24 Old 03-16-2010, 06:54 AM Thread Starter
Zen
^^ thanks for the link.
I went at lunch yesterday and bought a new cable for $35. I saved the link for when the new cable breaks.
Installing the new cable took about 20 minutes. There were no nuts or bolts holding it in place. The cable snapped onto the shifter and clipped into the bracket on the shifter. There's a gromet on the firewall that you push through to the engine bay. Then the cable clips onto the shifter bracket. The new cable has all new clips and a new gromet so if you break a stubborn clip or tear the old gromet, no worries. After the old cable is out, snap the new cable to the trans bracket, then route it up the firewall through the hole. Push the gromet through the hole, connect the new cable to the shifter bracket, and snap it to the shifter. Then line up and push the gromet back in place on the firewall. finally crawl under the Jeep and connect the cable to the transmission linkage. Check your shift points and make sure P=park D=drive etc. If not, adjust the cable by moving the bracket on the transmission end.
-Stick, splash one!
Zen is offline
post #8 of 24 Old 05-24-2013, 08:27 AM
NotURMailman
Just an FYI for anyone else that was searching and found this thread. The cable isn't $35 anymore, it's $50. Still not too bad. And the dealersip now sells just the bushings.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #9 of 24 Old 05-24-2013, 08:31 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Just get a replacement bushing from the dealer, I carry one as a spare.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #10 of 24 Old 05-24-2013, 09:30 AM
NotURMailman
Mine wasn't the bushing. The cable seized inside the sheath. So, I'll have bushings off of the old cable as spares.
post #11 of 24 Old 05-24-2013, 09:44 AM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
Anyone have a part number for just the bushing?
I am still on the original, so it would be good to carry a spare to go with the spare chopsticks for the already broken shift interlock rod.
TJDaveX is offline
post #12 of 24 Old 05-24-2013, 09:52 AM
NotURMailman
I would just call up the dealer.
post #13 of 24 Old 05-24-2013, 10:00 AM
TJDaveX
TJDaveX's Avatar
That's the plan, but it's nice to have a part# in advance to help guide the moron behind the counter, or on the phone.
I'll google it. Thanx.
TJDaveX is offline
post #14 of 24 Old 05-24-2013, 10:11 AM
NotURMailman
LOL! True...
post #15 of 24 Old 05-24-2013, 10:42 AM
Jerry Bransford
Administrator
I just so happened to still have that p/n on my cellphone for when I needed to buy one... 68137495AA.
Getting
Shift Cable Automatic Transmission RHODESIA TJ Wrangler Technical Forum 82 10-19-2015 09:34 AM
Automatic shifter FifteenCents TJ Wrangler Technical Forum 11 09-15-2009 08:15 AM
42RLE Shifter Cable Broke at Transmission undercoverfab TJ Wrangler Technical Forum 3 11-03-2008 10:19 PM
42RLE Automatic Shifter ??? ChadCielencki TJ Wrangler Technical Forum 1 01-04-2008 09:48 AM
automatic shifter knob kpatrick TJ Wrangler Technical Forum 4 10-31-2005 02:05 AM
