Automatic Transmission - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Automatic Transmission
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !
Unread 08-01-2010, 05:15 PM   #1
starkster
I am wanting to put either a 5.2 or 5.9 Dodge engine in my 2001 TJ. Will my automatic bolt up to either of these engines?
starkster is offline   Reply With Quote
Unread 08-01-2010, 05:27 PM   #2
starkster
Does the 2001 TJ automatic have the same bell housing bolt pattern as the TF727,TF904,TF999?
Thanks
Unread 08-01-2010, 05:37 PM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yes, its the same bolt pattern.
Wheelin98TJ is offline   Reply With Quote
Unread 08-01-2010, 05:40 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The bigger question is if you have the 30RH transmission used with the 2.5L engine which isn't up to being behind the 5.2L or 5.9, or the 32RH that the 4.0L engine uses that is.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 08-01-2010, 05:41 PM   #5
starkster
So I could bolt in a 5.2 or 5.9? I have 4.0 Automatic it should be stong enough for 2000 5.2 don't you think?
Unread 08-01-2010, 05:44 PM   #6
starkster
Auto trans
I have a 4.0 the trans should be stong enough don't think?
Unread 08-01-2010, 06:00 PM   #7
Jerry Bransford
Originally Posted by starkster View Post
I have a 4.0 the trans should be strong enough don't think?
That means you have the 32RH which should be. Chrysler has used members of the Torqueflite 999 auto transmission family behind lots of V8 engines, and the 32RH is a member of that venerable TF999 family.
Getting Savvy...
Unread 08-01-2010, 06:02 PM   #8
JBTJ
I think it should be OK. Though it wouldn't hurt any to tweek it a bit.
JBTJ is online now   Reply With Quote
Unread 08-01-2010, 06:26 PM   #9
TJJP77
New-Age Curmudgeon
TJJP77's Avatar
The "2" in 32RH is the input torque rating. Note that most transmissions used behind the V-8s have at least a "4" or a "5" in place of that "2". That isn't to say that your 32RH couldn't be built to handle the power - it's basically an A904 with a lockup torque converter, and there's plenty of beefed up parts available for this trans. If you use the 32RH, just exercise a little restraint with the gas pedal.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline   Reply With Quote
Unread 08-01-2010, 06:41 PM   #10
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Started a new thread did ya?
GOLENJEEPTJ is offline   Reply With Quote
Unread 08-02-2010, 12:22 PM   #11
starkster
Auto trans
Here's my thinking, I bought a Turbo kit and decided not too use it because of the heat. Sitting in traffic or offroad at a snailes pace the heat would kill the engine and electronics so my kit is going on Ebay. So my friends talked me into putting a 5.2 or 5.9 instead of the turbo. At 250-290 HP and 300+ lbs of torque and will run all day long without heat issues. Plus their going to help install it and they have a professional shop with asym. lifts. If I can use the trans in my Jeep that would save a few dollars for now so I can purchase a very low mileage engine and computer. I will run the trans in my jeep untill it gives up and have it built strong or replace it all together. I will keep you posted
Jim Stark
Unread 08-02-2010, 01:15 PM   #12
starkster
Auto Trans
Hey guys Iam totally confused, I was told that my bell housing is AMC pattern and a Dodge pattern. Hell, Me I don,t know I was a driveability mechanic. Advanced adapters also has a kit that you can bolt a small block Gen I to a TF727.TF999.
Unread 08-02-2010, 02:02 PM   #13
starkster
Trans low down
I talked with Advanced adapters awhile ago they said that RE32 is the same bolt pattern as the TF. But the best way too do the swap would be get motor and trans and computer as a package or put a STD. trans in it. I said ok then. Now I go shopping.
Unread 08-02-2010, 05:36 PM   #14
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Did you mean "32RH"?...
Knuckelhead is offline   Reply With Quote
Unread 08-02-2010, 05:50 PM   #15
starkster
yeah that's it
transmission , automatic
