Automatic shifter linkage - JeepForum.com
post #1 of 3 Old 02-25-2011, 03:33 PM Thread Starter
Stud_man50
So, after my jeep left me stranded and I thought the starter went out it was actually the shifter linkage at the transmission had came loose and it was stuck in reverse. The eye or socket has popped off the ball. You can put it bacshifted shift a few times but it pops back off. I have searched the forums and most posts go un-answered.... I need some guidance on replacement pieces. Thanks everyone
Stud_man50 is offline
post #2 of 3 Old 02-25-2011, 10:39 PM
Special_Z28
Try searching "auto linkage" by title specific.
Used this fix a couple years ago
http://www.jeepforum.com/forum/f9/05...ailure-600665/
Hope that helps!
1994 Camaro V6 3.4 (Mystic Teal)
1994
Quasar Blue
2005 Jeep Wrangler X 4.0L
Special_Z28 is offline
post #3 of 3 Old 03-03-2011, 04:34 PM Thread Starter
Stud_man50
Did you flatten the weld and drill from behind? I took mine off and I'll probably use the bench grinder at work and then use the drill press since it's available, instead of having my wife hold it while
I drill...
4WD Shifter linkage TJ_Jerry TJ Wrangler Technical Forum 5 02-10-2010 09:33 AM
how to adjust the automatic transmission linkage metalroses YJ Wrangler Technical Forum 0 10-15-2009 12:42 PM
T/C Shifter Linkage uvalax236 JK Wrangler Technical Forum 8 08-12-2009 09:22 PM
Shifter linkage?? Spigger73 YJ Wrangler Technical Forum 4 06-25-2008 09:04 AM
shifter linkage newtjrjrjr YJ Wrangler Technical Forum 7 01-05-2008 10:19 PM
