Auto Transmission Rough Shifts ! Advice needed! - JeepForum.com
post #1 of 6 Old 08-14-2015, 07:35 AM Thread Starter
APC686
I bought a TJ this week and have driven about 200 miles on it. So far I have had 1 really rough shift in a parking lot pulling into a parking space and another 2 or three noticeable rough shifts while driving. That first rough shift moved me in the seat and was audible to the point where my wife stared at me as if we would have to walk home. With 114K on the odometer and having no clue what the PO did or did not do for this jeep I'm afraid. I've got a 30 day warranty on it and it's been less than a week.The car dealer I bought it from was smaller and I don't trust them to check on it . I have no idea where my brain should be when it comes to concern. 42rle's have good reviews bad reviews flush them change the oil and filter, I don't know. I've got the month warranty clock ticking before this becomes my financial concern and not the dealers. I just want to know what the issue might be and what steps I should immediately take. First jeep purchased and I want it to last.
APC686 is offline
post #2 of 6 Old 08-14-2015, 07:54 AM
ravenworks
It probably a host of many things, I would tame it to a ASE mech and get documentation of what is wrong.
I had transmission,tourqe converter and PCM replaced,trust me it's expensive but I was under warranty.
All in all I would have been out $3600
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #3 of 6 Old 08-14-2015, 08:45 AM
1222
RIP John
1222's Avatar
Moved from JK tech.
(2011-2016)
1222 is offline
post #4 of 6 Old 08-14-2015, 09:29 AM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
Take it back ASAP and make them fix it until it's right. Most likely they send it somewhere else anyway.Fluid and filter change would be first up.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #5 of 6 Old 08-14-2015, 09:37 AM
GilaMtnJeep
GilaMtnJeep's Avatar
This^^^
Do not touch it yourself. As soon as you do you it's your problem. Find out what the laws are in your area. I would make them fix it or offer a full refund.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #6 of 6 Old 08-14-2015, 11:23 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I need your def of rough shift. I cant even see a shift puling into a parking spot - 1-2 occurs around 7MPH - that's rolling pretty fast to be cranking into a spot!
if the engine suddenly sped up and then engaged hard - that's not a rough shift. that's slipping. Take it for an inspect at a good mechanic.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
42rle , advice , advice help , shifting problem , transmission
