Auto Transmission - JeepForum.com
post #1 of 3 Old 08-04-2007, 08:16 PM Thread Starter
JeepPirate
Auto Transmission
The transmission is starting to go bad in my 97 Sahara, and there is a guy on craigslist that said he had an Auto transmission with electronic shift out of a 1998 Grand Cherokee. Will this fit a 97 TJ? I have a 3 sp auto, this guy isnt exactly sure what he has - he said all he knew was it was a auto with electronic shift with only 10k on it from under a 98 GC. Also, what rear axle is most common on a 98 GC, he is selling that too and I didnt know if I could go ahead and upgrade from my D35 with whatever comes under there.
JeepPirate is offline
post #2 of 3 Old 08-04-2007, 08:37 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
It would not be an easy fit into a TJ. I don't know if that trans has a stand alone computer or not, but your 3 speed auto is not electronic shift. If the trans from the Grand works from the main PCM, it would be a problem.
Either way its going to involve some pretty serious wiring.
The rear axle is a not worth pursuing either. Its either a D35 or a D44a which has an aluminum center section and limited aftermarket support.
Wheelin98TJ is offline
post #3 of 3 Old 08-04-2007, 08:41 PM
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
Go buy a 10$ bot. of Lucas Trans. fixer. give that a shot.
T
TrailWorthyFab is offline
***Simple: can I swap in a TF999 auto transmission into my 2.5L auto? phelan YJ Wrangler Technical Forum 2 02-07-2010 01:54 PM
auto transmission ? tekeum YJ Wrangler Technical Forum 2 01-02-2008 08:09 PM
Auto Transmission chrisra1 YJ Wrangler Technical Forum 4 08-04-2006 07:28 PM
Auto Transmission HELP!!! Rynxprs YJ Wrangler Technical Forum 3 09-22-2005 02:52 PM
Auto Transmission ForeverTheOptimist TJ Wrangler Technical Forum 5 05-22-2002 09:41 PM
