Auto tranny trouble shifting to 3rd when cold - JeepForum.com
post #1 of 9 Old 12-22-2009, 05:47 PM Thread Starter
b3nj4m1n
Not just when it's cold outside, still did it during the summer.
Anyway started about a year ago when i first start driving it will shift normally to 2nd but not to 3rd. If i play with the throttle a little bit i can get it to shift.
Doesn't happen after a few miles though.
been searching on the internet and found something similar with some guy's cherokee where it wouldn't shift from 1st to 2nd. someone replied:
Hey max, I have a 89 jeep cherokee laredo auto. 249,000k. I was having the same problem with my tranny. I looked everywhere online to find the problem, only to find that I didn't need anything new at all!(besides some new transmission fluid)
With a 1" wrench I disconnected the "speed-sensor" (which on 89's I'm told is the first year that they had them) I pulled out the cable and all I saw was a little square rod coming out of the end of the cable. It wouldn't move...?... I moved it in and out quickly so that is broke free of all dirt that was lodged inside of the cable. sprayed some degreaser, put it back! It shifts great!!
Transmission problem - Jeep Cherokee - Topix
is that the same speed sensor attached to the speedo gear? could that be causing the problem? other suggestions?
"Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin
"In the beginning of a change, the Patriot is a scarce man, Brave, Hated, and Scorned. When his cause succeeds however,the timid join him, For then it costs nothing to be a Patriot." -Mark Twain
b3nj4m1n is offline
post #2 of 9 Old 12-23-2009, 09:11 AM
troys96xj
You can try that and you can also take a steel wire brush and clean the shift linkage well , then spray WD-40 on it [spray generously] . Do that every 2 days for a week and see how it works. I had a few Chryslers that got gunked up on the linkage and this fixed it every time. Good luck.
troys96xj is offline
post #3 of 9 Old 12-23-2009, 01:29 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
When's the last time you changed the transmission fluid? Also, have you checked the adjustment of the TV cable? Do you have a FSM?...
Knuckelhead is offline
post #4 of 9 Old 12-23-2009, 01:30 PM
Knuckelhead
AFSOC Retired
What would that have to do with the internal shifting of the transmission?...
post #5 of 9 Old 12-23-2009, 02:56 PM
troys96xj
If the shift linkage has crap on it then it dont move like it should and therefor wont allow the tranny to shift properly. I know cuz Ive done it more than once. Im not saying this is the problem Im just saying it could be. If it is then its a free and easy fix. Chryslers are good for it. Im not stupid , I know what Im talking about.
post #6 of 9 Old 12-23-2009, 03:24 PM Thread Starter
b3nj4m1n
i have the fsm pdf.
i had the fluid and filter changed about a year and a half ago maybe..?
b3nj4m1n is offline
post #7 of 9 Old 12-23-2009, 04:20 PM
Knuckelhead
AFSOC Retired
i have the fsm pdf.
Other than the TV cable, have you looked at the two adjustments called out in the FSM?...
post #8 of 9 Old 12-23-2009, 04:22 PM
Knuckelhead
AFSOC Retired
Im not stupid.
And someone said you were?...
post #9 of 9 Old 12-23-2009, 05:26 PM Thread Starter
b3nj4m1n
haven't checked any of that. i did look at the fsm though and will check it out, thanks for the suggestions.
b3nj4m1n is offline
need help please (manual tranny shifting difficult when cold) chafalote TJ Wrangler Technical Forum 24 02-01-2016 07:31 PM
Trouble shifting when its cold mark12010 YJ Wrangler Technical Forum 14 12-08-2008 09:07 AM
Auto tranny not shifting out of first Billyjon1 TJ Wrangler Technical Forum 1 08-11-2008 09:38 AM
Manually shifting the auto tranny... Cavi JK Wrangler Technical Forum 12 01-06-2008 06:37 PM
Tranny shifting trouble bruce062 TJ Wrangler Technical Forum 5 05-23-2007 07:30 AM
