Auto 32RH shift shaft seal replacement. - JeepForum.com
post #1 of 4 Old 04-16-2014, 06:33 PM Thread Starter
motoxracer801
Hey all,
I have read all the posts on doing this. The only thing the post doesn't specify is how hard the new seal is supposed to be to go in.
I have a 2002 three speed auto jeep wrangler. I think I narrowed the tranny leak to the shift shaft. I did everything the posts I've read to a T. Which actually has been very simple up until now. I've already distorted one seal trying to get it in. This thing doesn't want to go back in. I tried tapping it with a small hammer. It was lopsided so I pulled it out. So then I tried running a bolt through it and putting same size washers on each side and wedging it into place that way. Nope.. that bent my brand new seal. So now it's back to OReilly for a new 8 dollar seal to bend. So what am I missing here? How do I get this back in place?
I'm getting better at all this stuff though... This home repair go around I've only threatened to sell my jeep two times!!
motoxracer801 is offline
post #2 of 4 Old 04-16-2014, 07:48 PM Thread Starter
motoxracer801
Nobody knows a quick simple way of doing this?
post #3 of 4 Old 04-16-2014, 08:24 PM
robncar
robncar's Avatar
Nope, apparently not. I read through the FSM and didn't see anything. Hopefully, you'll get someone that has replaced one to chime in.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #4 of 4 Old 04-16-2014, 08:25 PM
HAYSHAKER170
Check this link. I scanned thru it and did not find an answer to your question, but it may help you. Good luck.
http://www.scribd.com/doc/23066655/3...D-INSTALLATION
HAYSHAKER170 is offline
repair , seal , transmission , transmission leak
