aussie vs detroit ez locker for the front axle - JeepForum.com
post #1 of 18 Old 06-05-2008, 08:54 PM Thread Starter
gribbles
so I will be doing some axle upgrading shortly and was curious as to what type of front locker i would benefit the most from....(these 2 are in my budget) I know a ton of guys run aussies...but the ez locker is on sale for 199 right now...what are the differences between these 2? also what is the benefit one over the other, or are they very similar? What about installation of them...i really dont know much about the ez locker, i was planning on going with the aussie, but now that the ez locker is on sale, it too looks pretty attractive.
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #2 of 18 Old 06-05-2008, 09:20 PM
chappy84
chappy84's Avatar
I have an aussie and it works great. But in all fairness I have never had a detroit EZ.
Try reading the product review section of the forum?
-CHAPPY-
chappy84 is offline
post #3 of 18 Old 06-05-2008, 09:44 PM
tj99
tj99's Avatar
Same here I have an Aussie and have been very pleased with the results. Be prepared for some noise when they ratchet. Mine sounds like a tank occassionally when I turn.
1998 2.5L 5Spd - Sold
1999 4.0L Auto - Mine
2010 JKU - Sold
2014 JKU - Wifes
tj99 is offline
post #4 of 18 Old 06-06-2008, 05:51 AM
UTWeezul
Go with the Aussie or Powertrax, avoid the Detroit EZ locker. I had one and all I had out of it was problem after problem. It would never stay locked at all.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #5 of 18 Old 06-06-2008, 06:37 AM
ratster
I have a ez locker and have had no problems with it other than being pretty noisy.But if I had to do it over I would go Aussie just becuase of the ez's reputation for being problematic.
ratster is offline
post #6 of 18 Old 06-06-2008, 06:45 AM
FLATFENDER54
FLATFENDER54's Avatar
Do not get an ez-locker. They are pure peices of junk. (mine included) I have a brand new aussie in the box but still have not installed it.
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #7 of 18 Old 06-06-2008, 09:19 AM
rastadog
rastadog's Avatar
Ditto on the NO EZ Locker. They're similar in design to the Aussie but have more parts and I've heard of failures. I love my Aussie. I have to say it's been the single "most bang for the buck" mod I've done.
happy wrenching!
jim
2001 Anniversary Edition Wrangler
2.5" OME HD Lift on ProComp M/T 32"s. Aussie Locker in front. Skid Row armor & fresh radiator fluid.
XM Satellite Radio - SKYFi2 and some cosmetic mods.
rastadog is offline
post #8 of 18 Old 06-06-2008, 09:34 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Of all the lunchbox lockers, the EZ-Locker is by far the worst behaved out of the bunch. I prefer the Powertrax No-Slip locker up front as it never makes a sound and is totally invisible on the street, but it's around $100 more than the Aussie or Lockright which do make noise even in 2wd. But either the Aussie or Lockright would still be a great choice for the front, they're very popular for the front axle.
Gone wheeling Friday through Sunday.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #9 of 18 Old 03-15-2009, 07:03 AM
jeep2008
For use with Dana Model 30 front axle and open carrier. Lose all the noise of that ratcheting style locker without losing any of the performance! The No-Slip Traction System still uses side gears and couplers with teeth similar to the Lock-Right™, but special speed sensing devices allow the teeth to fully lock and unlock without any ratcheting or clicking. No clutch discs or friction plates to wear out, either! The No-Slip provides 100% traction when driving straight but fully unlocks during cornering, allowing for easy steering and reduced wear. Installs easily into your carrier, and most of the time the carrier can remain in the vehicle during installation. Made of Zytanium, a 9310 carbonized steel, for high strength and durability. Applications for open and limited slip differential carriers are available. *For 1997-02 TJ's, a front hub conversion is recommended.
why is that?
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #10 of 18 Old 03-15-2009, 07:56 AM
UTWeezul
Just remebered I had this video from my Detroit EZ Locker. It was installed correctly (we verified that upon install and upon removal to put in the Powertrax lock-right). Nothing was broken, that is just the sound of the horrible Detroit EZ Locker.
http://www.youtube.com/watch?v=fsvQjsUualE
35" MTR Kevlars
103" Wheelbase
UTWeezul is offline
post #11 of 18 Old 03-15-2009, 10:18 AM
Jerry Bransford
Administrator
why is that?
First, why did that recommendation cut off after 2002? There's no difference in the axles or 4x4 system in any of the TJs between 2002 and older and 2003 and newer. So that statement is very misleading. Second, no hub conversion is needed whatsoever, whoever said tht is 100% wrong. Whoever wrote that, and I assume you cut and pasted that from a different source, doesn't know jack about the TJ.
Getting
post #12 of 18 Old 03-15-2009, 11:34 AM
jeep2008
Well guess what??It is from the same people that sell the c-clip eliminator for 1200$ when all the other world sells them for 650$!!!! http://www.4wd.com/productdetails.as...07&partID=5241
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #13 of 18 Old 03-15-2009, 01:22 PM
GMBNT42
Can someone explain to me what the term "lunchbox" means please?
A quick question for those with knowledge:
I am ordering up an Eaton gear driven LSD for the rear D44 replacing the stock clutch driven unit the D44 comes with on my LJ. Should I go with another one up front, or go with some type of basic locker. 4wd on my vehicle most likely will be a 75/25 split being used for snow/ice in winter, and some occasional trail riding, light off(no rock crawling) roading in the spring/summer.
GMBNT42 is offline
post #14 of 18 Old 03-15-2009, 02:49 PM
EvilM0nkey
EvilM0nkey's Avatar
A lunchbox locker just replaces your spider gears, not the carrier. Not too much of an issue for the D30 unless you have huge tires. It's pretty strong as is.
-Ross
EvilM0nkey is offline
post #15 of 18 Old 03-15-2009, 03:28 PM
GMBNT42
OK so how do these lunchbox lockers work exactly? like the recommended powertrax unit. Since there is no hub to lock, or air/electric actuator.
GMBNT42 is offline
Aussie Locker in 03 TJ front axle Rubblex TJ Wrangler Technical Forum 9 06-01-2015 06:34 PM
Dana 44. Aussie Locker Or Detroit? mitch_brown YJ Wrangler Technical Forum 5 10-23-2009 07:11 PM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
Detroit VS Aussie EZ Locker MickBurke TJ Wrangler Technical Forum 10 02-22-2008 05:08 PM
Front Locker: Detroit E-Z vs Aussie prossett YJ Wrangler Technical Forum 10 03-11-2005 03:59 PM
