Aussie Locker Question - JeepForum.com
post #1 of 9 Old 02-18-2009, 06:58 AM Thread Starter
HoustonTJ
A question for people with aussie lockers front and rear.
I installed the Aussies front and rear on my TJ. Both passed the spin test and in 2wd I can feel the rear pushing the inside tire especially turning from a stop. Iím planning on going to Superlift ORV in Hot Springs with a friend next weekend. Then I thought I havenít put the jeep into 4wd since both front and rear were installed and I better check that out before driving 9 hours to get there. So out there in the (Paved) parking lot I pulled up on the magical 4x4 lever. Hereís where the questions is.
1. Driving straight or mostly straight is ok.
2. Attempting to turn into an angle parking spot got exciting??? Itís like everything was locked up. Tires are chirping and hopping.
3. Iím not sure I could do a turn with the wheels fully turned, partially turned started to plow across the pavement.
I expected it to tighten up and produce more centering force on the steering, but itís like it doesnít want to turn at all.
OK now for the question.
Is everything ok?
Is this dramatic ďFull LockĒ due to the paved surface?
Even after going back to 2wd it took a few side to side turns to loosen up the front end.
I donít have my installation measurements here at work, but the front was mid range on all of them. The rear was in spec, but on the tighter side.
Thanks,
Steve
HoustonTJ is offline
post #2 of 9 Old 02-18-2009, 07:10 AM
BarneyJEEP
yup, that's why you're not supposed to use 4wd on pavement...
BarneyJEEP is offline
post #3 of 9 Old 02-18-2009, 07:21 AM
ROUGHSHOD
ROUGHSHOD's Avatar
I have one in the front and it does the same thing - it means you've installed it correctly. When switching from 4WD back to 2WD it will unlock more easily after you've run it for a while.
ROUGHSHOD is offline
post #4 of 9 Old 02-18-2009, 07:25 AM
CTOffroad
Everything is good, just next time please don't do that on pavement, do it in the dirt where there is some give.
Carolina Truggies - Dream it, Build it, Love it
www.carolinatruggies.com
CTOffroad is offline
post #5 of 9 Old 02-18-2009, 07:26 AM
cj847
Bad idea to run in 4wd on pavement. It is a PART TIME transfer case which means the only time you use it is when you are in a low traction condition. You can do serious damage on pavement.
You have a locked tcase and locked differentials. So, in theory it is impossible to do anything but go in a strait line. Any move you make from a strait line requires that a tire slips, chirps, lifts off the ground, or something breaks.
Other than that, it sounds like everything is working great. Have fun in Hot Springs.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #6 of 9 Old 02-18-2009, 07:49 AM Thread Starter
HoustonTJ
I basically got the same answer from Aussie, but wanted to see what the forum's thoughts were.
Thanks for the replies!
post #7 of 9 Old 02-18-2009, 08:43 AM
alexr40
yeah on the pavement 4x4 you have the 2 rear tires locked, the 2 front tires locked, and the front and rear driveshaft locked at transfercase
so you are fully locked. no tire can spin different from the other.. That's why it jumps/hops and cant turn right
that's normal. you should use it only on the dirt/trails.. You will see you can turn and it will not hop or anything. because it will slide on the dirt/sand etc.
rule of thumb.. 4x4 only off road........ if you are front/rear locked... this rule is even more strictly! for your safety and for the safety of your drivetrain components.
1998 Jeep Wrangler 2.5L Turbo @11psi
Locked Front & Rear, 4.56s, 4:1 low range with 2LO. 35's with Beadlocks .
2005 WK Limited 4.7L - 4x4 (QT-II)
2" RC Lift, 265/70/17 BFG AT/KO, OME Rear Shocks, Saguaro Shackle Mounts, Mopar OEM Hitch
alexr40 is offline
post #8 of 9 Old 02-18-2009, 08:44 AM
silverjeep
Yup, your locked and loaded. Go wheel that thing. You'll be amazed at what you can do now.
Jeep parts and accessories
silverjeep is offline
post #9 of 9 Old 02-21-2009, 06:14 PM Thread Starter
HoustonTJ
Found some dirt today and tried 4wd again. MUCH better!
Thanks for all the replies.
aussie locker question plyguitar45 YJ Wrangler Technical Forum 14 05-13-2009 11:25 AM
About to buy Aussie locker. 1 question... dolphy TJ Wrangler Technical Forum 2 03-01-2009 08:40 AM
Yet another Aussie locker questionÖ Asored2000 TJ Wrangler Technical Forum 7 05-16-2008 12:55 PM
Aussie Locker question jmhat98 YJ Wrangler Technical Forum 4 04-28-2007 09:14 AM
Aussie Locker Question 2004Jeeptj111 TJ Wrangler Technical Forum 18 03-08-2007 04:30 PM
