Aussie Locker install in a D30 writeup ! - Page 3 - JeepForum.com
post #31 of 38 Old 11-13-2010, 06:30 AM Thread Starter
TeeJay00
Originally Posted by nibstools View Post
Did this install front and rear in my YJ thing is a beast with both! Very easy install.
Why is the locker in the first picture different than the one in the rest? Which carrier is that?
TeeJay00 is offline
post #32 of 38 Old 11-13-2010, 09:41 PM
JChors
When you go to mark your ring/pinion position, use a crayon or grease pencil, or score it lightly with a screwdriver. I used a Sharpie and it's mark was lost when I lubed the locker with axle grease prior to reassembly, as recommended by 4x4xplor.com's write-up.
JChors is offline
post #33 of 38 Old 11-13-2010, 10:43 PM
nibstools
That is the same locker. Just took a pic before I started greasing it all up. All those pics are from the Front install (D30)
nibstools is offline
post #34 of 38 Old 11-14-2010, 02:14 AM Thread Starter
TeeJay00
Yes but the locker in the first picture has a different shape!!! I was just wondering that's all
TeeJay00 is offline
post #35 of 38 Old 11-14-2010, 02:18 AM Thread Starter
TeeJay00
Note the differences...
TeeJay00 is offline
post #36 of 38 Old 11-14-2010, 05:53 AM
nibstools
you are right, I think I downloaded that first picture from the companies site. must be a model for a different axle. But they still work awesome! In these two videos both these guys struggled with the hill or couldn't make it at all. The blue YJ has an ox locker rear. The TJ has a lunchbox in the front. Of course no one videoed me but with both lockers in mine I just creeped up the hill, no trouble at all
YouTube - nibstools's Channel
post #37 of 38 Old 11-14-2010, 06:00 AM Thread Starter
TeeJay00
I know what you're talking about... I have the Aussie in front and LSD in the rear and as I said before, wow what a difference it made
TeeJay00 is offline
post #38 of 38 Old 11-14-2010, 06:24 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Originally Posted by fishinjeeper View Post
by placings the pins and springs reverse. It turns the Aussie into a full time locker. Not sure why, some have explained it to be but I did not understand. I installed completely installed everything including my Aussie. I tried to back out of the drive way and could not turn my wheel at all. It was obviously fully locked. So I took it apart and switched the pins and springs and worked just like it should!
you didnt do the click test as per the instructions to see if it unlocks? before putting the cover back on, this should be done. you need to watch the locker unlock for both sides.
Mail crawling.
MisfitSeven is offline
aussie locker , dana 30 , locker install , lockers
Aussie Locker Install Difficulty? DIY? Dealer Wants 1k To Install.... rastaangel TJ Wrangler Technical Forum 14 04-12-2010 07:00 PM
Aussie Locker Install... corvetteguy YJ Wrangler Technical Forum 12 10-22-2009 03:51 PM
Aussie Locker Install. whitie_08 YJ Wrangler Technical Forum 35 02-22-2009 06:44 PM
BL, MML, Aussie Locker Install djXternal TJ Wrangler Technical Forum 8 12-26-2006 03:48 PM
Aussie Locker Install on D30 rick75089 YJ Wrangler Technical Forum 18 04-21-2004 02:02 AM
