Aussie Locker install in a D30 writeup ! - Page 2 - JeepForum.com
post #16 of 38 Old 11-12-2010, 01:09 PM Thread Starter
TeeJay00
Originally Posted by del_TJ View Post
Thanks for the write-up. I'm thinking of putting an Aussie in my LP30 next year.
Do you notice clunking or clicking at full turn? I don't doubt the added off-road capability, but I hear different things about how quiet they are on the street under 2WD. Some say they're totally silent, others complain of hard clunking under tight turns. What should I expect?
It does clunk a bit at full turn but it's not that bad really... The rest of the time on the road it has no effect or noise at all. Infact it's so quiet on 2wd I thought I must have installed incorrectly ! Untill I tried it today and as I said it worked like a charm
Go for it
TeeJay00 is offline
post #17 of 38 Old 11-12-2010, 01:11 PM Thread Starter
TeeJay00
Originally Posted by mschviuz View Post
Mine clicks during turns but to me it isn't noticeable anymore. My wife, however, drove my jeep the other day and calls me saying it is making a weird noise. After going crazy in my head, thinking "oh great, now what's wrong with my jeep", I figured out she was talking about the locker.
The noise really isn't very loud and I will tell you it is about the best $200 you can put into you jeep for cost/benefit offroad
I'm with you all the way
TeeJay00 is offline
post #18 of 38 Old 11-12-2010, 01:19 PM
purplepig
fishinjeeper, can you elaborate on what you are referring to?
purplepig is offline
post #19 of 38 Old 11-12-2010, 01:41 PM
mschviuz
The springs/pins are put in opposite of how they should be installed....
mschviuz is offline
post #20 of 38 Old 11-12-2010, 01:58 PM
tufrthnails
Love my Aussie in my LP30 running it with 35's for 3 years now. Clicks a little in low speed tight turns otherwise silent. Hated it in my Rear end (8.8). Had to either throttle through turns or coast no in between. It would clunck pretty hard when getting in throttle or out of throttle in a turn.
2002 TJ "Bad Monkey"
"Enough Mods the wife still isn't talking to me!"
Lakeland Jeep Club Treasurer
tufrthnails is offline
post #21 of 38 Old 11-12-2010, 03:00 PM
purplepig
I see now. hehe
post #22 of 38 Old 11-12-2010, 03:37 PM
fishinjeeper
by placings the pins and springs reverse. It turns the Aussie into a full time locker. Not sure why, some have explained it to be but I did not understand. I installed completely installed everything including my Aussie. I tried to back out of the drive way and could not turn my wheel at all. It was obviously fully locked. So I took it apart and switched the pins and springs and worked just like it should!
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #23 of 38 Old 11-12-2010, 04:43 PM
conrasm
conrasm's Avatar
Have one in my XJ D44 and loved it. I had to removed the ring gear as well. The cross shaft would not clear the teeth.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #24 of 38 Old 11-12-2010, 06:03 PM
Jeepzcb09
Ive never seen a Aussie for the HP D30, they all say D30, do the work for both the LP and HP?
1998 TJ Sport : Rough Country, MetalCloak,KC, Goodyear, Crager, Alpine, AtoZ, Currie, Aussie
Believe.
Jeepzcb09 is offline
post #25 of 38 Old 11-12-2010, 11:23 PM Thread Starter
TeeJay00
Yes
TeeJay00 is offline
post #26 of 38 Old 11-13-2010, 12:25 AM
JChors
Mine's totally unnoticable in 2wd. In 4wd it let's you know it's there in all the turns.
JChors is offline
post #27 of 38 Old 11-13-2010, 05:10 AM
gitractorman
Were you able to take apart the axle, install the locker, and re-install the ring gear without making any adjustments to the gear/pinion alignment? I have heard that making sure the ring gear is in perfect alignment with the pinion gear is a must whenever taking a differential apart? I know that some places use marking paper to measure clearances, etc. I've never done it, so I'm just curious if you should be going to an axle shop to make sure the alignments are still good.
gitractorman is offline
post #28 of 38 Old 11-13-2010, 05:22 AM
Contra
ust make sure you keep the bearing cap on the correct side when you put it back on and tourque it and with the ring gear also mark it with a sharpie so that you put it back in the exact sam place and tourque it aswell
Ever Gone Geocaching?
Contra is offline
post #29 of 38 Old 11-13-2010, 06:22 AM
nibstools
Did this install front and rear in my YJ thing is a beast with both! Very easy install.
aussie locker.jpg   carrier cleared out.jpg   Aussie installed in carrier.jpg   Aussie installed in carrier ring gear on.jpg   carrier back in axle.jpg
nibstools is offline
post #30 of 38 Old 11-13-2010, 06:26 AM Thread Starter
TeeJay00
Yes when I found out how easy it is to install an automatic locker I am now working on getting my rear D44 locked aswell
But I think I'm gonna go for powertrax lock-right this time... Not sure though!
TeeJay00 is offline
aussie locker , dana 30 , locker install , lockers
Aussie Locker Install Difficulty? DIY? Dealer Wants 1k To Install.... rastaangel TJ Wrangler Technical Forum 14 04-12-2010 07:00 PM
Aussie Locker Install... corvetteguy YJ Wrangler Technical Forum 12 10-22-2009 03:51 PM
Aussie Locker Install. whitie_08 YJ Wrangler Technical Forum 35 02-22-2009 06:44 PM
BL, MML, Aussie Locker Install djXternal TJ Wrangler Technical Forum 8 12-26-2006 03:48 PM
Aussie Locker Install on D30 rick75089 YJ Wrangler Technical Forum 18 04-21-2004 02:02 AM
