Aussie Locker in D35c - Page 6 - JeepForum.com
post #76 of 110 Old 07-21-2010, 05:15 PM
2006_Sport
Hot tub time machine!
2006_Sport is offline
post #77 of 110 Old 07-21-2010, 05:25 PM
SLADE
Really? You don't remember? Let's get in the way-back machine!
You didnt do very well in reading comprhesion did you? Don't feel bad, I'm not the best speller (as has been pointed out)
Look at what you just quoted, I never said I broke a S35. I stated that I wasted money on a Super 35 kit.
Is your only argument for a S35 is that I'm lieing? Thats great! why would I lie and what do I have to gain by lieing about my experiences and opinion of a Dana 35 to a bunch of guys that I don't even know? Breaking a dana 35 doesnt really earn me any cool points. Your funny.
SLADE is offline
post #78 of 110 Old 07-21-2010, 05:32 PM
never monday
because any ******* with a heavy foot can break a D35c. It takes a special kind of retard to break a Super 35.
never monday is offline
post #79 of 110 Old 07-21-2010, 06:22 PM
Apex
Recon death squad
Apex's Avatar
Originally Posted by never monday View Post
because any ******* with a heavy foot can break a D35c. It takes a special kind retard to break a Super 35.
Bingo!
Apex is offline
post #80 of 110 Old 07-22-2010, 02:44 PM Thread Starter
cbrookerd
I found a guy selling a rear axle out of a '99 explorer for $90! I would have to drive 200 miles to get it and it is has 3.73 gears...should i go for it?
cbrookerd is offline
post #81 of 110 Old 07-22-2010, 03:01 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Only if you are willing to go to all the effort and expense it will take to get that 8.8 axle ready to install into a TJ. There is a lot of cutting, grinding, and welding to get the old brackets out and new TJ brackets in their place so it will bolt into place. Not to mention the cost of regearing it. I can't see that $90 axle costing less than $900 before it's ready to install unless you knw how to do all or much of that on your own.
Jerry Bransford is offline
post #82 of 110 Old 07-22-2010, 03:21 PM
SLADE
Last 8.8 I setup for a TJ was ready to bolt in for less than $400. The guy that I set it up for didnt have any where near $900 in it.
SLADE is offline
post #83 of 110 Old 07-22-2010, 03:54 PM
Apex
Recon death squad
Apex's Avatar
Nice, let me guess. Already had the gears he wanted in it, or you set them up for him? You know how to weld? You made your own brackets?
Now I want a show of hands from the rest of you guys who can:
1. Set-up your own gears?
2. Weld?
3. Fab your own brackets?
Ok, how many of you put your hands up? Only a couple of you? Thought so.
If I found an 8.8 with 4.10 gears in it for $200, I could have it in my Jeep for $250.
BUT the majority of the people out here would have to have it built by a professional. From the gears, to welding the brackets that they bought off of a website.
I am a fan of the 8.8, for the guy who can do the work himself...its a great upgrade if you can build it yourself, otherwise it costs as much as the s35 to do correctly.
Apex is offline
post #84 of 110 Old 07-22-2010, 04:52 PM
Deacon
Shining Adonis
Deacon's Avatar
Is it already pulled, or will you have to do that? If you have to do it, do you have the tools and know-how to get it done?
You've got 3.07 gears which means not only will you need to regear the front, but you'd need a whole new carrier as well.
I also have no idea what the best ratio is for the 32rh on 33's. I think 3.73 may actually work alright, though IIRC 4.11 might be preferable? Someone else would have to say for sure.
By the way, fill out you profile with technical data whenever possible. Under transmission it just says "Auto" which isn't good enough...
Deacon is offline
post #85 of 110 Old 07-22-2010, 04:54 PM
SLADE
Brackets where bought, not built. The owner had around $700+- in the 8.8 swap. I didnt know the guy, so he didnt get a good buddy discount.
Even after paying someone to weld on brackets, you can still have an 8.8 for less than other options.
Don't throw the gears up like it's an added expience that only applies to the 8.8. The gears are an expience across the board regardless if you go with an 8.8/44/ or S35(gear setup is a must regardless if you regear). UNLESS you are content with 4.10 gears and find a Rubi 44 or an 8.8 or do not need a gear change and can just match your 3.55, 3.73, 4.10. Since budget is allways such a factor, the 8.8 will allow you to match your gears your currently running so you can put off the cost of a complete regear untill the buget can increase and to avoid a wasted setup fee (Installing S35 without regearing) If a S35 is an option, the plans must be to stay in the 33"-35" tire range. In that case 4.10s will work(unless your packin a 4 banger). They wouldnt be ideal for 35's, but when you want to upgrade on a budget, it's not that big of a sacrifice. In that case, going with the 8.8 will save you setup costs. Disc brakes are a no cost gain for it. How much will it cost to swap the 35 to disc?
Consider all aspects of all the options. there isn't 1 option that is right or better for everyone. Look at what your getting without a biased eye and get some actuall prices of labor and parts that YOU can get.
SLADE is offline
post #86 of 110 Old 07-22-2010, 05:27 PM
never monday
a S35 can be done in the driveway by anyone with patience that can read a manual.
and, if 4.10 is such a big deal.....start with a TJ 4 banger axle set
post #87 of 110 Old 07-22-2010, 05:35 PM
SLADE
Didnt realize setting up gears was so easy.
SLADE is offline
post #88 of 110 Old 07-22-2010, 05:46 PM
never monday
maybe you should learn how
Install: Super35 Ox locker with AlloyUSA 30 spline shafts
post #89 of 110 Old 07-22-2010, 06:03 PM
SLADE
SLADE is offline
post #90 of 110 Old 07-22-2010, 06:17 PM Thread Starter
cbrookerd
I have a guy down here that quoted me $200 to regear the front, and $350 to do the back including gearing and fabbing the 8.8 to fit...i supply all hardware of course....i would never go bigger than 35s as far as tires, and i will have to find my build sheet to fill out the details on my tranny...
The cost of the 8.8 is reasonable...but not "cheap" like some make it sound....since i don't weld or gear
aussie , d35 , dana 35 , jeep , locker , tj , wrangler
Aussie locker VS. Yukon Spartan locker fishinjeeper TJ Wrangler Technical Forum 126 07-15-2015 05:55 AM
D35c Build. LSD/Locker, Clip Elim/S35? Washi TJ Wrangler Technical Forum 21 11-09-2009 07:15 AM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
OX Locker in D35c 0II0 TJ Wrangler Technical Forum 61 08-15-2008 04:26 AM
LunchBox Locker Install in Rear D35C, HELP NEED INFO! CanukYJ YJ Wrangler Technical Forum 2 12-04-2003 01:44 PM
