Aussie Locker in D35c - Page 3 - JeepForum.com
post #31 of 110 Old 07-18-2010, 08:33 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Originally Posted by DoctorPhate View Post
I believe what hes going by is that prices on axles relative to inflation will go down therefore why spend now when you can easily spend later.
Personally I could argue with the better half and put the 8.8 in mine right now and buy a set of gears for it but I know over time the cost goes down and I'm going to wheel my D35 until it breaks at which point i'll put in my spare shafts and put in the 8.8. Why? It came with the D35 and I got the shafts for free.
So I'm basically taking the same path as this guy, I'm hardly easy on it but I do look at things and say "well If i gun it and i slip I will snap that shaft I'm 90% sure.. I'll go that way"
the cheap way isnt the right way. the guy asked for advice, hopefully he takes the good advice since he is getting some pretty good stuff. just because you're not doing it the right way doesnt mean you should suggest it to other people as i have told you before.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #32 of 110 Old 07-18-2010, 08:54 PM Thread Starter
cbrookerd
I may just end up ordering one of the 8.8s from Complete Ford 8.8" Rear Axle Assembly Jeep TJ Ready to Bolt In Axle Swap once i save up the money....sell the aussie i got for trade....broke atm as far as jeep upgrades are concerned, so it's no big rush to make a decision.
cbrookerd is offline
post #33 of 110 Old 07-19-2010, 07:21 AM
DivineKaos
I have to second what TJ Boomer has said.
I am hard on my vehicles. As is my friend I go wheeling with all the time. He has aussies front and rear, D30/D35 (I have one only in my D35). Both of us run 33s.
In 5 years for him, he has never broken an axle shaft, nor a ring and pinion. He pushes it hard. He doesn't go easy on the skinny pedal. Is he the exception to the rule? Possibly. But I haven't had a problem either...most of the people in our club (about 500 strong that have Jeeps)- run D35s.. I have yet to see a broken D35 axle from a 33" tire that was locked. I saw it happen only once, and that was running 39s, with a welded rear.
The key is to know the limits. Don't bounce the vehicle if your trying to get over an incline when it starts hopping its time to let off the pedal.
I unfortunately do not have an unlimited cash flow- and I can get a set of replacement shafts for about $60.
I can't get over how condescending some of you are being.
Because you say its right, makes it right? Get over yourself.
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #34 of 110 Old 07-19-2010, 08:56 AM
Apex
Recon death squad
Apex's Avatar
I don't get this mentality. We are condescending because we are trying to talk someone out of doing something that will potentially do more harm than good.
Sure, shafts are only $60, and your Aussie was only $250.
So that is $310 you COULD have put towards a better axle or axle kit. Then your ring and pinion goes, that's $500. So your aussie was $250, your shafts were $60 and your R&P was $500...that's $810 that could have BOUGHT you a better axle or axle kit. I don't have unlimited funds either, I build things slowly and save my money so I can do it right and NOT BREAK THINGS. I try not to be the trail liability. I don't want to be the guy everyone has to worry about. Sorry if that sounds condescending, because it isn't.
Apex is offline
post #35 of 110 Old 07-19-2010, 03:38 PM Thread Starter
cbrookerd
The locker i now have cost me nothing...does that not change the tune? I need to regear anyways and the guy won't charge me anymore to put the locker in...
post #36 of 110 Old 07-19-2010, 03:42 PM
never monday
to me it doesn't.
I see selling that locker and being 150-200 closer to a better axle. See the locker it's self is not the problem. The rest of the POS crap D35 carrier that the locker lives in. Plus the POS stock 1.16" dia shafts.
never monday is offline
post #37 of 110 Old 07-19-2010, 03:56 PM Thread Starter
cbrookerd
Well, I'm still considering that approach...but what about a super35 kit without a locker and then put the aussie in then? Seems like a good way to save $300 ...or just superior shafts and new ring and pinion since i need to regear anyway? I just hate to have to buy a locker instead of beefing up my d35 a bit so I could use it comfortablycomfortably
post #38 of 110 Old 07-19-2010, 04:00 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Won't work, the Super 35 kit from Superior Axle doesn't come with an empty 30 spline carrier, it only comes with a full case locker like an ARB, Detroit Locker, etc.
Jerry Bransford is online now
post #39 of 110 Old 07-19-2010, 04:01 PM
jeepinmichguy_
Soar Forever Six
aussie wont work with a super 35. they have 30 spline shafts.
jerry beat me to it.
ΜΟΛΩΝ ΛΑΒΕ
post #40 of 110 Old 07-19-2010, 04:09 PM Thread Starter
cbrookerd
Hmmmmm....then what about the upgraded chromarly shafts then?...or something else that is stronger and affordable?
post #41 of 110 Old 07-19-2010, 04:31 PM
never monday
that just buys you time.
Seriously, The other parts in the axle that surround a 27 spline Aussie are complete crap.
Get a S35 kit. You get a billet full case locker, 30 spline 1.3" dia chromolly shafts. The correct carrier split for the gears you are going to.
post #42 of 110 Old 07-19-2010, 09:58 PM Thread Starter
cbrookerd
what about something like this? Alloy USA 12200 - Alloy USA Rear 27 Spline Peformance Axle Kit for 90-06 Jeep® Cherokee XJ, Wrangler YJ & TJ with Dana 35 Axle - Quadratec
obviously quadrec's prices are usually pretty steap, but even from them, this is a fairly minor investment ($300+ shipping)....new r&p for regearing to either 4.11 or 4.56, r&p for D30 up front to match, and use the free aussie in the rear....this would be a total investment of about $1200 tops including labor and would give me new gears front and rear, upgraded axle shafts in rear, and a locker....this seem like a decent move to you guys?
the 8.8 from east coast gears, built up with a locker and read to bolt in, is like $1200 on it's own, not including shipping or labor to install, and I would still need to regear the front, which would be another 400-500 bux or so....
I priced an 8.8 at a couple of junkyards around here, and they want $350 for it...then I have to get the kit and pay labor to have it built....putting the investment to around $800 or so...assuming I found one with the gear ratio I want, then I would just have to get the r&p for the d30, plus labor, so I would still be around $1300 invested....assuming I wouldn't need new brakes and **** for the junkyard 8.8....
cheapest s35 kit I could find was about $1000...then I would still have to regear...
post #43 of 110 Old 07-19-2010, 10:33 PM
RaggedOleMan
Everyone seems to be overlooking the Superior 27 Spline C-Clip Eliminator. Those USA made shafts are 27 spline and they will work with a lunchbox, and no change to your carrier or gears is necessary. And, I'm not aware of any instance where anyone has broken a 27 spline Superior CCE shaft, locked, on 33's. That said...
I agree that the carrier & ring and pinion then become the weak link in the d35 chain. So, easy on the spendy pedal is still in order..
RaggedOleMan is offline
post #44 of 110 Old 07-19-2010, 10:40 PM
Hrothgar
Band wagon in full effect today I see, keep up the good work fellas.
Hrothgar is offline
post #45 of 110 Old 07-20-2010, 02:26 AM Thread Starter
cbrookerd
aussie , d35 , dana 35 , jeep , locker , tj , wrangler
Aussie locker VS. Yukon Spartan locker fishinjeeper TJ Wrangler Technical Forum 126 07-15-2015 05:55 AM
D35c Build. LSD/Locker, Clip Elim/S35? Washi TJ Wrangler Technical Forum 21 11-09-2009 07:15 AM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
OX Locker in D35c 0II0 TJ Wrangler Technical Forum 61 08-15-2008 04:26 AM
LunchBox Locker Install in Rear D35C, HELP NEED INFO! CanukYJ YJ Wrangler Technical Forum 2 12-04-2003 01:44 PM
