aussie install screw up - JeepForum.com
post #1 of 18 Old 08-03-2010, 05:45 PM Thread Starter
yellowjesus
In the middle of my aussie install into my d30 and i ran into a problem. I have 3.07's so i do not need to remove the carrier i can but i dont need to. I tried to punch out the pin that holds the cross shaft for the spiders in and its almost out and the bit i was using snapped inside and it hasnt moved since...pretty pissed any ideas to get it out. without removing the carrier would be better since i tried to and it doesnt seem to want to come out. Thanks guys
yellowjesus is offline
post #2 of 18 Old 08-03-2010, 05:47 PM
tjdriver
were you using a punch? i say just keep working at it and if you can't work it out you may have to pull the carrier.
wish i had better advice for ya. good luck.
tjdriver is offline
post #3 of 18 Old 08-03-2010, 05:47 PM
MC_NickP
to remove the carrier, slide the axle shafts out, and use a pry bar between the carrier and the housing to get it out. its alot easier if u take the carrier out. as far as the snapped bit problem, use another bit i guess.
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
MC_NickP is offline
post #4 of 18 Old 08-03-2010, 05:52 PM
monkeygruven
just leave it in there, how much could go wrong?
Originally posted by MotoSoul:
The real trail rated badges are located on your skid plates.
monkeygruven is offline
post #5 of 18 Old 08-03-2010, 05:59 PM Thread Starter
yellowjesus
very funny...but i guess ill just have to keep trying and yeah already got the shafts out and everything just this one little thing...just my luck
post #6 of 18 Old 08-03-2010, 06:38 PM Thread Starter
yellowjesus
got the carrier out but now the pin wont budge at all still im pretty annoyed i dont know what else to try
post #7 of 18 Old 08-03-2010, 06:43 PM
SILASPRIT
The cross-pin should slide out effortlessly. You took out the little bolt that holds in the cross-pin right?
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline
post #8 of 18 Old 08-03-2010, 06:44 PM
dennis461
1991 XJ Cherokee
post a pic
Post a pic of what you've got.
A broken drill bit is going to be a real bugger to get out.
dennis461 is offline
post #9 of 18 Old 08-03-2010, 06:51 PM Thread Starter
yellowjesus
no its the pin that hold the cross pin in ...my genius dad decided to try to help and stick some like idk what it was ..like a skinny file into it and it snapped when i realized what he put in it i flipped out and have been banging on it to get it out for about 2 hours now ..i was thinking i would need to drill it out but that scares me
post #10 of 18 Old 08-03-2010, 06:58 PM Thread Starter
yellowjesus
the pin is sticking out about an inch how long is it just so i know how much is left in it
post #11 of 18 Old 08-03-2010, 07:08 PM
viperbluelx
If the pin is sticking out 1", then grab it with some pliers and pull it on out.
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #12 of 18 Old 08-03-2010, 07:50 PM
gremlinsteve
or tap it in reverse and know out that broken punch
gremlinsteve is offline
post #13 of 18 Old 08-03-2010, 10:49 PM Thread Starter
yellowjesus
i got it out i just got a bigger hammer and as i grew angrier it worked its way out..since the pin is hollow the thing he used as a punch just slid inside and seperated it and as i drove it down it just went deeper and made it get stuck more...its all done now so i should be all set it in the morning, i hope i put the spacers facing the right way i cant remember which way i put them i hope it doesnt hurt anything if i didnt.
post #14 of 18 Old 08-03-2010, 11:07 PM
SILASPRIT
The carrier shims?!?! YESSSS those NEED to be in how you took them out or you could screw things up perty bad. If you don't remember, you need to have to have the back-lash verified before you jack up your gears.
-SOLD-
post #15 of 18 Old 08-03-2010, 11:27 PM Thread Starter
yellowjesus
no or atleast i dont think they were the carrier shims, it was the peices that came with the locker. the only peices without the teeth on them, it said to make sure the flat sides face each other and im pretty sure thats how i put it though
aussie , locker , install , carrier , remove , removing , d30 , danan 30
Aussie Install D30 RaggedOleMan TJ Wrangler Technical Forum 20 11-06-2010 07:14 PM
Aussie Locker Install Difficulty? DIY? Dealer Wants 1k To Install.... rastaangel TJ Wrangler Technical Forum 14 04-12-2010 07:00 PM
8.8 aussie install LeeGro TJ Wrangler Technical Forum 8 03-23-2008 08:08 PM
d30 aussie install Q? blurunner YJ Wrangler Technical Forum 9 08-14-2007 09:50 PM
Aussie install foreman1063 TJ Wrangler Technical Forum 0 09-09-2005 02:50 PM
