Aussie Auto locker/Factory LSD/Detroit TruTrac - Page 2 - JeepForum.com
post #16 of 59 Old 06-29-2010, 07:21 AM
little_Jeep
Originally Posted by cpu77 View Post
Hmm well as for upgrades I agree if you are wheeling put a 8.8 ford in there. However I really don't wheel. I am just regearing for my 33's. I figure why in there why not add a LSD. As for the front I wish I could hear it in person. Does it click like a bad CV joint or bind like when it's in 4wd turning.
No binding..... just several rapid clicks.... probably like what you think of a bad CV joint would do. It's an auto locker, they have some minor quirks. If you don't wheel, and you drive at higher speeds in 4wd, I'd leave the sucker open. You can always add a lunchbox locker such as an Aussie at any time without much fuss.
little_Jeep is offline
post #17 of 59 Old 06-29-2010, 10:22 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by little_Jeep View Post
The Aussie, like any auto locker, will click on sharp turns (like when pulling into a parking space), but other than that, you will seldom know it's there when you are in 2wd.
The No-Slip auto locker is the exception, it does not click whether you're in 2wd, 4Hi, or 4Lo. I ran a No-Slip in my front axle for probably 80K miles and never heard it click even once.
Gone on vacation until August 25.
Jerry Bransford is offline
post #18 of 59 Old 06-29-2010, 11:33 AM
IslandTJ
Will the Detroit TruTrac in the D35 be well mannered and quiet?
Absolutely!
Now Jeeping in Oregon
IslandTJ is offline
post #19 of 59 Old 06-29-2010, 12:22 PM Thread Starter
cpu77
Jerry the link I provided to the Aussie is not the one you are speaking of?
1999 White Jeep Wrangler
4.0/5spd/4.56 Gears
2" BB with 305/70/16 MTR's W/Kevlar
JKS Rear Track Bar
cpu77 is offline
post #20 of 59 Old 06-29-2010, 12:30 PM
little_Jeep
You and I just have a difference of definition of terms Call me a snob, but I don't think of a limited slip as a locker. I don't think of a limited slip as being trail worthy. However, in this situation, we are talking about a Jeep that the owner says he only Mall Crawls with. Considering this, I would give the idea of leaving both diffs, especially the front one open. I understand these are my opinions and you are welcome to disagree with them.
post #21 of 59 Old 06-29-2010, 12:31 PM
Jerry Bransford
Administrator
No, the Aussie is a completely different locker and is not the same as the click-free Powertrax No-Slip locker I mentioned above.
The part number for the correct No-Slip locker for your front Dana 30 axle is 92-0430-2700 which can be found on
http://www.richmondgear.com/powertrax/jeep1ns.pdf
Pay no attention to the remarks on that page under the "NOTICE REGARDING FRONT AXLE APPLICATIONS:" heading. That generic warning does not apply to the type of 4x4 system used by the Wrangler TJ.
post #22 of 59 Old 06-29-2010, 12:32 PM
IslandTJ
Uhmm, the "No-Slip" is an actual automatic lunchbox locker. It's not a limited slip
IslandTJ is offline
post #23 of 59 Old 06-29-2010, 12:35 PM
Jerry Bransford
Administrator
Do a little research before erroneously claiming the No-Slip is a limited slip differential. It's not a LSD, it's a full automatic lunchbox locker just like the Aussie, Lockright, and EZ-Locker is.
post #24 of 59 Old 06-29-2010, 12:53 PM
little_Jeep
Maybe I'm from the old school.... No-slip was/has been nothing more than slang for a limited slip. I'll follow the link you posted and read up on this sucker.
post #25 of 59 Old 06-29-2010, 01:23 PM
Jerry Bransford
Administrator
"Old school" or not, and I'm very likely a lot older than you, I wouldn't claim something we're referring to as a locker is a limited slip without checking up on it first. Here's a decent review of the No-Slip locker for you to read... Powertrax No-Slip
post #26 of 59 Old 06-29-2010, 01:34 PM
RaggedOleMan
I run the Aussie up front (d30) and love it. Just bought a Powertrax "No Slip" for the rear + a Superior CCE. Budget driven, (not to mention Jerry's positive comments on the USA made Powertrax) I expect it to have tolerable street manners, and outstanding trail manners. Thanks Jeep Forum...
RaggedOleMan is offline
post #27 of 59 Old 06-29-2010, 01:36 PM
LuckRider
LuckRider's Avatar
Did you get the 30 spline or 27 spline CCE? If you got the 30 spline, you need a new carrier, and you won't be able to use the No Slip. I am going to assume you got the 27 spline though.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #28 of 59 Old 06-29-2010, 02:08 PM
little_Jeep
I run an Aussie up front as well and love it....... just not in my DD and not in a vehicle that I drive on slick/ice/snow covered roads in 4wd. The original poster is in Ohio (snow/ice/slick roads) and this is his none wheeled daily driver.
post #29 of 59 Old 06-29-2010, 02:09 PM
little_Jeep
I'm in a little rush at work, but I'll follow your link... to see what you are talking about.
post #30 of 59 Old 06-29-2010, 02:27 PM
RaggedOleMan
Thanks LuckRider, I appreciate your thought's...
Yes, I did get the 27 spline so I could stay on budget. I should be okay on 33's, at least I believe I will. 35's likely wouldn't be wise on the 27 spline CCE, eh?
locker comparison , locker
Dana 44. Aussie Locker Or Detroit? mitch_brown YJ Wrangler Technical Forum 5 10-23-2009 07:11 PM
aussie vs detroit ez locker for the front axle gribbles TJ Wrangler Technical Forum 17 03-17-2009 08:41 PM
Detroit VS Aussie EZ Locker MickBurke TJ Wrangler Technical Forum 10 02-22-2008 05:08 PM
Detroit Trutrac 3.07 / 35? BEANS TJ Wrangler Technical Forum 20 12-15-2005 06:52 AM
Front Locker: Detroit E-Z vs Aussie prossett YJ Wrangler Technical Forum 10 03-11-2005 03:59 PM
