AUGUST TJ of THE MONTH!! XtrmTJ IS THE WINNER!! - JeepForum.com
post #1 of 42 Old 08-30-2010, 11:07 AM Thread Starter
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Congratulation to XtrmTJ, the August 2010 TJ of the Month!
We had another impressive top 10 this month and I am looking forward to seeing how next month turns out. Keep submitting, keep voting, and lets keep this contest running strong!
XtrmTJ
Username : XtrmTJ
Mods :
SPEC SHEET: 1997 Jeep TJ / Sahara
1. 1979 HP/D44, full width front axle with 5:38 Yukon gears, Detroit Locker, Yukon inner and outer axle shafts. Warn locking hubs, Rock Crusher diff cover, QA1 3/4” Hiem jointed tie rod that is 1 1/2” X .310 walled DOM, flipped on top the knuckles for a little extra clearance. Custom bridge work to locate the custom 3 link/Wishbone system.
2. 1978 Ford 9”, full width rear axle with 5:43 Yukon gears. Yukon Spool and 31 splined Yukon axle shafts. A Randy’s Ring & Pinion experimental (thick/beefy) third member. A ¾” thick DIY yoke/u-joint skid plate. A 3/8” thick steel skid plate welded to the bottom of axle. A 3/8” steel plate molded/welded on back cover to protect the ring and pinion. Custom bridge work to locate the custom 3 link/Wishbone system.
3. MPFI 4.0L inline 6 cylinder. (Just turned 39,000 miles) new factory “flex” header, K&N air filter, custom exhaust with a series 50 Flow Master muffler. Jet one inch TBI spacer. The OBA is a 1979 Ford A/C pump plumbed onto the factory A/C stand. A Summit Racing electric radiator fan. M.O.R.E. two inch raised motor mounts. Custom oil pan skid plate. Battery and Engine block warmers (Canadian model) Dual Optima red top batteries in an M.O.R.E. dual battery tray. Custom made (PVC pipe) radiator overflow and window washing fluid tanks.
4. TF 999 automatic transmission with a Currie deep oil pan (prevents fluid starvation at extreme angles) and a custom oil pan skid plate. Summit add on transmission oil cooler.
5. NP 231 transfer case. TeraFlex SYE kit, TeraLow 4:1 kit, mounted on a custom reinforced Teraflex “belly-up” skid plate.
6. Custom front and rear drive shafts, made from 2” X .250 walled DOM. Tom Woods long splined / long travel slip yokes with gold band1310 u-joints.
7. Front axle is moved forward 5.5” and is located by a custom “Wish Bone” three link system, using 1.75” X .250 walled DOM, the lower arms are 48” long X 1.75” X .250 walled DOM sheathed with schedule 80 pipe. All Hiem joints are QA1’s of ¾”” and 1 3/4” sizes. The front rides on a pair of 14 inch Sway Away Race Runner coil over’s with dual rated springs (10” 150 lbs over 14” 300 lbs) and 6” tender coils. The front brake lines are extra long and steel braided. Steering is controlled by a 2 X 8 inch hydraulic ram, with an add on electric fan cooled oil cooler, and a high volume PS pump with a smaller Power Pulley.
8. The rear axle was moved 9” backwards for a 109 inch wheel base, and is located by a custom “Wish Bone” 3 link system, using 1.75” X .250 walled DOM, the lower arms are 48” long X 1.75” X .250 walled DOM sheathed with schedule 80 pipe. All Hiem joints are QA1’s of ¾” and 1 3/4 “sizes. The rear rides on 5.5” over stock, Rubicon Express rear coils. The rear coils are captured on top and free at the bottom. The rear axle was clocked upwards for a perfect drive shaft angle. The rear shocks are Gas charged Les Schwab Mountain Rider Extremes, angle inboard for better articulation.
9. A two (2) inch “Bod-i-Lift” was installed to accommodate the Terraflex belly-up / skid pan. The rear of the frame was cut off and 3X4X3/8 inch tubing was added to extend the wheel base and attach the Rubicon Express rear coils. The stock fuel tank was removed and a custom, 16 gallon fuel cell was placed in the cargo area. The entire tub of the Jeep was coated with Hurcaliner bed liner. A Toys by Troy cage was welded in with extra support members (5 in all). A Grant steering wheel with a quick release system. Passenger side Air Bag was removed. KC Rock and off road lighting. A hood lift system. A pair of recovery shackles front and rear. 40 channel CB. Dual Air horns. Fire extinguisher.
10. Custom armor plating includes Avalanche Rocker Knockers w/custom nerf bars added and Compitition cut rear Crusher corners. The tail gate was removed and replaced with ¼” plate steel. A Blue Torch Fab front hoop and stinger combo. A custom made winch mount. A Warn HS9500I winch. Custom made “flat” front fenders. Front and rear LED turn/stop signals.
11. All this rides on 15X39.5X15 Super Swamper TSL’s mounted on 12X15 steel rock crawler rims with DIY 24 bolt custom bead locks.
12. Recent mods, Rear Bumperetts, Military tail/turn lights, Military door safety straps, Drivers fender blackout light, MB side and corner handles, Pioneer gear mounted (axe/shovel), .50 Cal ammo can used as a center console (lockable), MB side/rear view round mirror, Hand grenade (pineapple style) shifter knob. 20MM ammo can in rear as tool/gear storage, MB style hood latches. Everything painted Green, with Military markings painted Flat Black.
Story :
Eugene is a 1997 Jeep TJ. Eugene started out life as my wife’s daily driver and grocery getter. A mild 1.5” puck lift and 31” Super Swampers were all he got. He was given to me in May of 1999 and work began on him in June of 1999. After countless hours researching the web, talking to other Jeepers, looking, learning, figuring out the geometry, trials and errors, after many, many, … many,….. “ MANY” modifications, he now is ready to attack anything that gets in his way!
It was small little steps at first, trial and error stuff really. Then it happened, I was afflicted, a sickness my wife says, Eugene went from mild to wild ! From 29’s to 39’s, from factory OEM to one off custom everything. I have been wheeling Jeeps for over 20 years and finally built one that does it all, looks cool cruzing the strip on Saturday night and can negotiate the nastiest terrain in North America. Looks, Form, Function, I wouldn’t change anything, I know every nut, every bolt, every scratch, every dent, every noise he makes is music to my ears. Eugene is perfection in motion!
Pics:
2016 TJ of the Year
Founder, Offroad NC
Follow our journey:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
EugeneTheTJ is offline
post #2 of 42 Old 08-30-2010, 11:12 AM
HHI-Dave
Yeah!
Let me be the first to say "Congrats!"
Next month....Flatlander!
HHI-Dave is offline
post #3 of 42 Old 08-30-2010, 11:16 AM
NotURMailman
Congrats!
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #4 of 42 Old 08-30-2010, 11:55 AM
flatlander757
Congrats!
Now wheel it! And get pics
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #5 of 42 Old 08-30-2010, 12:34 PM
TurtleMacLeod
Well done! Definitely an impressive rig!
2 XJs, a ZJ, a TJ, a JK . . . Now in an LJ!
RED JEEP CLUB #602
TurtleMacLeod is offline
post #6 of 42 Old 08-30-2010, 12:38 PM
bige2533
Congrats on a great Jeep. On a side note, please spay or neuter your Jeep to keep control of the Jeep population.
bige2533 is offline
post #7 of 42 Old 08-30-2010, 12:43 PM
nwiTJdave
YUT!
Congratulations. Nice looking Jeep
This is for fighting, this is for fun.
nwiTJdave is offline
post #8 of 42 Old 08-30-2010, 12:59 PM
steve578
steve578's Avatar
Congrats! A lot of great Jeeps this month.
2013 JKUR
steve578 is offline
post #9 of 42 Old 08-30-2010, 01:09 PM
Marauder_Pilot
Marauder_Pilot's Avatar
That Jeep is AWESOME!
The Truck Nutz gotta go, though.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #10 of 42 Old 08-30-2010, 01:10 PM
XtrmTJ
First, I would like to thank everyone that voted for me! Next, I want to thank JF for putting on TJoTM ! I am truly humbled, seeing the company I am in. Any of the Top Ten could be TJoTM, I am honored that you selected “Eugene”. I am the FNG here but I don’t feel like it, I have been warmly welcomed and made to feel at home, Thank You.
I wheel ! (before his new look)
GREEN JEEP CLUB Member #516
It's a ROCK, ... get over it !
XtrmTJ is offline
post #11 of 42 Old 08-30-2010, 01:26 PM
Gunkel
Gunkel's Avatar
Congratulations on the much deserved win!!
I would say you definitely wheel your rig, those pictures are awesome
Gunkel is offline
post #12 of 42 Old 08-30-2010, 01:31 PM
Gl0b3y
Congrats, very nice rig
Gl0b3y is offline
post #13 of 42 Old 08-30-2010, 01:47 PM
snowcrash
snowcrash's Avatar
2014 JK Wrangler
If I had to lose I'm glad it was to that sick Jeep! Hell I almost voted for it over myself anyway haha.
Congrats man.
That jeep is nutz....... Or would that be has....
Anyway, killer Jeep!
-Aaron
2014 Billet Silver Rubicon
4.56, 35" MTZ on 17" ATX Slabs, Mopar Stage 3 lift kit, Evo front and rear bumpers, Evo stinger, AEV snorkel, Smittybilt GEN2 winch, aFe Hi-Tuck exhaust, Teraflex tire carrier, Bestop Twill Trektop NX, a bunch of lights and more stuff coming every day!
I still miss my 2006 TJ!
snowcrash is offline
post #14 of 42 Old 08-30-2010, 01:56 PM
DezertTJ
congrats! awesome jeep
DezertTJ is offline
post #15 of 42 Old 08-30-2010, 07:57 PM
XtrmTJ
Thank you all, your kind words are really appreciated !
Here are a few more pics, enjoy !
XtrmTJ is offline
TJ OF THE MONTH WINNER ANNOUNCED!! Alex71 IS THE JANUARY 2010 WINNER!! spyder6 TJ Wrangler Technical Forum 42 06-01-2010 10:02 PM
TJ of The Month Winner Announced!! RedLyner is the December WINNER!! spyder6 TJ Wrangler Technical Forum 36 01-12-2010 12:26 PM
TJ of The Month Contest winner announced!! FourbyCor is the October WINNER!!! spyder6 TJ Wrangler Technical Forum 28 11-30-2009 11:28 AM
TJ of The Month Contest Winner Announced!! GUNKEL IS THE SEPTEMBER WINNER!! spyder6 TJ Wrangler Technical Forum 40 10-26-2009 08:23 AM
TJ of The Month contest WINNER ANNOUNCED! -sean- IS THE AUGUST WINNER!! spyder6 TJ Wrangler Technical Forum 32 09-16-2009 07:28 PM
