ATX Artillery Rims on Wrangler TJ? - JeepForum.com
post #1 of 7 Old 09-06-2011, 02:27 PM Thread Starter
OlympicMaple
Hey, guys! I'm new here and this is my first post. I'm looking at buying a used '97 TJ in the next few months and I'm dreaming of all the possibilities and options to choose from when customizing these beasts. I really like the ATX Artillery rims, but I've never seen them on a TJ before. Do you know if they will fit the TJ bolt pattern and if they will have enough room for backspacing? If you have have these rims on your TJ feel free to post pictures!
Thanks.
OlympicMaple is offline
post #2 of 7 Old 09-06-2011, 02:47 PM
mattlock1983
mattlock1983's Avatar
welcome to the forum.
there is a boatload of information contained within these servers.... and you are on the right track by reading up on here before you buy your jeep. I trolled this forum for about a year before i bought my jeep; and i learned a LOT, so that by the time i bought my jeep i already knew quite a bit about it.
i had never heard of those rims, so i typed them into google and this is what came back:
(apparently they will fit a JK bolt pattern)
(i know, its not a picture of a TJ, but it still conveys the ugliness of those ricer rims on a jeep)
2004 Rubicon Artic Silver, Automatic
~2.5" Lift, LT285 MTR's, Currie HD steering, Currie Anti-Rock, Nth Oil Pan Skid, Kilby Steering Skid, Warn HS9500, Rockcrusher Diff covers, Nth Slider rear DS skid, custom bumpers, PIAA reverse lights, Tuffy Console, Uniden PC78 elite CB, Nth TT (not installed)
mattlock1983 is offline
post #3 of 7 Old 09-06-2011, 03:04 PM Thread Starter
OlympicMaple
Thanks, Mattlock! So the bolt pattern of a JK is the same as a TJ? I'm basically just looking at wheels and it seems there's a lot that I have to learn. Figuring out how to shop for tires is an entirely different story, haha. So much to choose from!
post #4 of 7 Old 09-06-2011, 03:12 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
TJ bolt pattern = 5 on 4.5.
JK bolt pattern = 5 on 5
Stock TJ backspacing = 5.5" and will fit up to a 10.50 wide tire.
To fit 11.50 tires on a TJ, you need 5" or less backspacing. To fit a 12.50 wide tire, you need 4.5" or less backspacing.
Every 1" of tire width increase requires a 1/2" of backspacing decrease.
Wheelin98TJ is offline
post #5 of 7 Old 09-06-2011, 03:36 PM
flying_bosun
No, TJs and JKs have a different pattern. You can get wheel spacers to correct the pattern, but that'll change you backspacing, too.
^ this.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #6 of 7 Old 09-06-2011, 06:20 PM Thread Starter
OlympicMaple
Okay, that makes sense to me. I'm learning something new already, this is great! Question: For 90% on-road use and about 10% medium-hard off-road use, should I be looking at approximately 9 or 10 inch wide tires... or is that over-kill? I'm thinking 17x8" rims, with 33" inch tires. What is the largest width I can get out of a tire on an 8" wide rim? I find the whole "picking tires and rims" to be really confusing. I don't have much knowledge on the subject.)
post #7 of 7 Old 09-07-2011, 08:18 AM
Wheelin98TJ
JEEP FREAK
8" wide wheels work well for up to 12.50 wide tires. You can even do 13.50 wide tires, but that is about as wide as I would go.
9" wheels work well for up to 13.50 or 14.50 wide tires.
A good rule of thumb is the wheel should be approximately 2/3 to 3/4 the width of the tire.
That is not what the tire and wheel guys recommend. They will tell you that you need a 10" wide wheel for 12.50 wide tires.
The narrower 8" or 9" wide wheel works better for how we use our Jeeps. The narrower wheel holds the tire bead better when aired down. You just have to run less PSI on road so you get even tread wear.
Wider wheels allow you to run a little more PSI. More PSI usually gives better MPG, however wider wheels stick out more and they make the tire a little wider. This increase in resistance is probably enough to wipe out the minimal gain from the slightly higher PSI. It should handle a little better with the wider wheels. The wider stance and less sidewall balloon should make it a little more stable.
rims , tj , wheels , wrangler
Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION makstuss JK Wrangler Technical Forum 3 02-20-2011 05:23 PM
would 09 wrangler rims work rigger YJ Wrangler Technical Forum 3 01-22-2010 07:56 PM
Difference in JK Wrangler spoke rims and JK Rubicon rims? CMT1 Wrangler General Discussion 3 09-04-2009 12:39 PM
rims for a wrangler scbasspro YJ Wrangler Technical Forum 4 07-05-2009 10:18 PM
Will 07 Rubiconn rims fit 92 wrangler moparcas YJ Wrangler Technical Forum 3 11-07-2008 08:45 AM
