ASD shutdown relay-Kill Switch - JeepForum.com
post #1 of 4 Old 06-25-2010, 08:03 AM Thread Starter
jeepbreath
All,
I want to install a simple kill switch into my 2000 TJ. I have researched this extensively on JF and have yet to find the answer I am looking for. I believe the easiest method would be to install a simple on/off switch into the ground for the ASD relay, which on my model can be found at connector C-106/pinout #4 (dark blue wire) under the driver's side dash. I have read several posts regardings the ADE-II kit that splices into this same wire, but uses a relay and a magnetic reed switch. I like the idea, but from a cost perspective believe a switch would be much cheaper. I also like the idea of installing the SKIM, but I would be out between $150-$200 and just can't swing it right now.
Some feedback would be appreciated from anyone who has gone this route. Also, why would you use a relay on such a small gauge wire when a switch should be sufficient enough to handle the amp/voltage?
Thanks,
RB
jeepbreath is offline
post #2 of 4 Old 06-25-2010, 08:36 AM
Faramir66103
This is exactly what I've been thinking about. I'd also prefer something simpler (i.e. less components to fail) than the ADE kit. That circuit runs through the fuse panel behind the glove box. I've got a Tuffy glove box so I'm going to install a heavy duty SPST switch with a cover into it and mount it on the glove box. Since I almost always open the glove box to get the stereo face plate out or put it away, flipping one switch will be pretty simple and I think secure.
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
post #3 of 4 Old 06-25-2010, 07:26 PM
Neil F.
All you need to do is cut the wire and install a switch (in a location of your choice)
Neil F. is offline
post #4 of 4 Old 06-25-2010, 09:14 PM
Mlehnert85
2009 JK Wrangler
Originally Posted by jeepbreath View Post
All,
Thanks,
RB
I installed one today...not a real hard project by any means.....I spliced into a wire going from a the ASD relay to the fuel pump relay. In effect tapping into the fuel pumps power source. Works great and on top of that...if I ever decided to remove it I only need to replace a 4in wire.
Mlehnert85 is offline
kill , switch
Trouble wiring auto shutdown relay switch vettefever5 TJ Wrangler Technical Forum 3 12-25-2011 12:11 PM
Auto Shutdown Relay Nuge TJ Wrangler Technical Forum 0 04-26-2009 03:41 PM
HELP!!!!Where is the Auto shutdown relay xsidewinder YJ Wrangler Technical Forum 26 11-04-2007 05:24 PM
91 yj automatic shutdown relay? Warrensparadise YJ Wrangler Technical Forum 5 03-15-2007 01:51 PM
fuel pump relay - auto shutdown hakebros YJ Wrangler Technical Forum 3 08-06-2003 08:29 AM
