Quantcast Area lights = Fog lights? Directional lights = driving lights? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Area lights = Fog lights? Directional lights = driving lights?
Old 07-10-2006, 01:10 AM   #1
Dr. Marneaus
Hairy Armgina
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
When reffering to the 2 different types of lights, I have always said "area: or "direcitonal" lights. Looking at KC slimlights and other things, I have noticed they are called "driving" and "fog" lights.
I assume the driving lights are like head lights? They are focused, and thus are high powered, directional lights?
And fog lights means they are not so long ranged, but a wider area?
I just need this cleared up.
thanks folks
Andrew - Landscape architect in training. Not landscaper
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
"One of the best ways to get yourself a reputation as a dangerous citizen these days is to go about repeating the very phrases which our founding fathers used in the great struggle for independence" - Charles Austin Beard
OOoooh, it's a killin' machine! It's got everything! Like a drivin' power, big fat tires, and everything!
- Deep Purple
The Beast Build Thread:Marns '73 Wagoneer Thread ----- Gone but not Forgotten:97 TJs Build Up.
Dr. Marneaus is offline   Reply With Quote
Old 07-10-2006, 01:21 AM   #2
dirtbagofva
2010 JK Wrangler
you are correct in your assumption...more or less. Lights can range from spot to flood and some can have patterns. Fog lights are short range broad area, Driving lights have a narrow flat pattern and cast light almost as far as a spot light. There are some lights (Tractor supply/Northern) that are inbetween, Trapazoid.
Headlights fall into the middle between Fog and Driving lights
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline   Reply With Quote
Old 07-10-2006, 02:46 AM   #3
/\/\uD b0gg3r
yes driving lights are directional long range beams and fog lights are area lights. if you want lights that can do both, check out these warn lights:
http://www.warn.com/truck/lights/sdb-160hbe.shtml
that is what im running right now.
/\/\uD b0gg3r is offline   Reply With Quote
Glock Forum
