#151 | |
those are some real nice gains
#152 |
I am still working on mine. I used a rightangle grinder with cutoff wheel to take care of my rocksliders. If the fenders wouldn't be so expensive I could have bought your rock sliders to bolt on.
I could could not see spending the money for something that I allready have and can modify. I am sure you guys at MetalCloak can understand that. I am very happy with the kit. Seems to be going well. The only problem I have had so far was I broke the vacum line off the little box that hides under the battery tray. I don't think it will too hard to fix. Another thing is I dont know where my battery hold down braket goes. I have not looked at it in a few days or remeber seing it in the directions as to how this gets bolted in. But I am sure I just missed it in the directions. If someone could take a pic from looking down at the front of the battery that would help me out. But really know need to i guess. I should be able to figure it out.
4" short arm lift, Anti rock sway bars front and rear. hard rock Front and rear bumbers, Warn 9.5ti winch,Undercover fab engine and tc skid,genright extreme gas tank, AtoZ Fabrication rocker guards, metal cloak fenders all around,JKS bar pin elminators, Viair Extreme Duty OBA system, Cobra CB, 37'' iroks on trailready beadlocks , NP231 Novak shifter tera low 4:1 with 2 low kit and SYE , CV ds, rockjock 3 front and rear dana60's with front and rear ARB with 4:88's.PSC hydro assist |
#153 | |
My build thread: http://www.jeepforum.com/forum/f9/rubiconrazorbac-build-thread-792423/ |
#154 | |
MetalCloak'd
TJ/LJ Instructions
It's Your Jeep, Only Better. | MetalCloak.com | 6PakRevolution.com MetalCloak Clearance Diagrams... MetalCloak vs. Others The Arched Tube Fender Exposed - A Start to Finish Review |
#155 | |
#156 |
Well I have not gotten there in the instructions yet. That is why I didn't know what to do with it. I just now saw this in the instructions given in preveous post. So all is well. I just figured that It should have gone in when I thought it should.
I was wondering about the battery hold down braket. Just to clear things up a little.
#157 | |
The battery sits a little higher so when you put the hold down bracket on it's a TIGHT fit. But, you just feed the J-arms down through the front & back wide holes, then shift it a little 'til the short end comes back up through one of the small round holes on either side. So you're "hooking" the tray. Then tighten as needed.
#158 |
Just a couple comments:
Sometimes, I just don't like to disco my front sway bar. My sway bar end-links use to like getting into the inner fender during moderate wheeling even more than the stock. Here's how I made it stop on mine. There are two bolts that hold the inner fender to the grill on each side. If you loosen those a tad after everything else is installed, you can hit the forward edge of the inner fender with a rubber mallet. This will flush it to the grill and get you an extra 3/4" - 1" clearance for the end link to move up. hit at the red x's till it's flush then tighten the bolts back down. ![]() If you user the stock sway bar, then you need to make sure it stays centered by getting two collars from McMaster Carr. Here's a write up: Jeep Swaybar Shifting Over Fix Link to the collars $6.82 each: McMaster-Carr Installed: ![]() The next tip is if you have a black jeep. The back of the grill is unfinished and ugly with over spray from the factory. This is the perfect match for your Jeep, and hard enough to not chip. Hit up the area you want to paint, with a scratch pad, wipe it with some cleaner, tape it off, shoot some primer and then 2-3 light coats. Gloss Black #7579 ![]() It's a bit dirty and I should have got the bolts while I was at it, but you get the point ![]() ![]() The same paint matches the powder coat that came on the 1st Gen fenders perfectly Ill add. Easy touch ups! Dunno if they changed it. For comparison: (Picked this one because its black and I like New Castle )![]() |
#159 | |
#160 | |
just loosen grill bolts, push the inner fender well toward the engine at the spots marked with "X" (above) with your hand then retighten the grill bolts. This is not necessary on most after market sway bars but it can't hurt to do it anyway. |
#161 |
Vector6...thank you for the clarification, we follow the manufacturer's specification Cardinal C241-BK01 TDS, the post you are quoting is just a quick overview of the process. We kind of thought if we showed every single step of every process we would lose our readers...lol.
#162 | |
#163 | |
#164 |
ok i got a question for metalcloak: are you planning a highline arched tube fender kit? this may have been asked b4. i dont know tho. thanks
#165 | |
MetalCloak'd
The Arched Tube fender is already considered a Hi-Line in that it gives Hi-Line clearance without having to replace or cut the hood. At this point we don't see any need to create a version that requires users to do any body modification. Though we never know what the future holds! You can see the actual clearance gained in this thread... http://www.jeepforum.com/forum/f9/metalcloak-clearance-diagrams-metalcloak-vs-others-842196/ ![]()
It's Your Jeep, Only Better. | MetalCloak.com | 6PakRevolution.com MetalCloak Clearance Diagrams... MetalCloak vs. Others The Arched Tube Fender Exposed - A Start to Finish Review Last edited by matsonian; 11-27-2009 at 12:14 AM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
