ARB Tire Inflation Kit - JeepForum.com
post #1 of 12 Old 11-24-2006, 11:31 PM Thread Starter
Idahomie
Anybody ever used it, if so does it work good?
JH
Idahomie is offline
post #2 of 12 Old 11-24-2006, 11:36 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
No, it does not work good for anything other than refilling the occasional low tire. It doesn't pump out enough air volume (not to be confused with air pressure) to refill tires at anything other than an agonizingly slow rate.
Plus it's not rated to run the length of time needed to refill four big Jeep tires aired down for offroading. Doing so on a regular basis will shorten its life. Unofficially per ARB's reps, they doesn't even recommend using their tire inflation kit for more than occasional low tire fill-up.
Jerry Bransford is offline
post #3 of 12 Old 11-24-2006, 11:41 PM Thread Starter
Idahomie
Right on man,
Thanks for the tip. Glad I asked before buying.
JH
Idahomie is offline
post #4 of 12 Old 11-24-2006, 11:41 PM
CETROV
CETROV's Avatar
I have the ARB compressor and would never use it for an inflation - way slow.
I also have the Viair 400 and a 2 gallon tank which works well with my 35's.
97 TJ
CETROV is offline
post #5 of 12 Old 11-25-2006, 06:00 AM
yellj
That's the same set up I have, works great, can air up in about 10 minutes, would be there about 10 minutes a tire with the ARB, which would probably burn up after that kind of use, not because it's a bad compressor, that is just not what it is made for.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
yellj is offline
post #6 of 12 Old 11-25-2006, 08:47 AM
kizer
kizer's Avatar
I wouldn't recommend using your ARB compressor as a Tire inflator, but more or less as a backup. Ive built my own.
http://www.links4jeeps.com/writeups/arb_inflator/
Ive found it works, but as a backup. I currently use a 25 compressor that I bought from a local parts store. Works great and when it dies it only cost me 25bucks compaired to a 200 ARB compressor.
1600+ Write-ups, and more
kizer is offline
post #7 of 12 Old 11-25-2006, 11:41 AM
Stu Olson
Stu Olson's Avatar
Jerry,
While I totally agree that the ARB compressor is not well suited for airing up large tires, the new style compressor (the smaller unit that was introduced about a year ago) has a 100% duty cycle. I exchanged some comments with one of the ARB engineering supervisors from Australia back then....one of their acceptance tests was 35 PSI for 30 hours, cavitated over pressure testing at over 220PSI, and deliberate stone blasting in the wheel well of a Land Rover Defender. All this (and more) was done just to be sure it would not overheat while airing up your tire.
The same can not be said for the older ARB compressors.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #8 of 12 Old 11-25-2006, 11:44 AM
Jerry Bransford
Administrator
Good to know they improved their duty cycle to 100% Stu, thanks for that update!
post #9 of 12 Old 11-25-2006, 06:04 PM
yellj
I have the new mini, while it is great for lockers, even saw a demo video where it worked under water, but I couldn't imagine it airing up a single tire in under 15 minutes, just not much volume, not designed for that as the lockers need very little volume. Thought the original question was it any good for airing up tires, answer is no, unless it is an emergency and you have plenty of time. Just for giggles, here is a pic of the set up with Viair and the mini (CKSA12), like have a redundant source of air. I don't believe it is 100% Duty Cycle, here is the specs from ARB, note the CFM .47 @ 29 PSI, 35% Duty Cycle, thier specs
http://www.arbusa.com/air_compressor/specifications.pdf
http://i61.photobucket.com/albums/h6...j/100_0651.jpg
yellj is offline
post #10 of 12 Old 11-25-2006, 06:57 PM
Stu Olson
Stu Olson's Avatar
Originally Posted by yellj
I have the new mini, while it is great for lockers, even saw a demo video where it worked under water, but I couldn't imagine it airing up a single tire in under 15 minutes, just not much volume, not designed for that as the lockers need very little volume. Thought the original question was it any good for airing up tires, answer is no, unless it is an emergency and you have plenty of time. ....
I don't think anyone posting here supported the idea of using it to air up tires.
Everyone's response, including mine, said it's not a good choice for airing up tires.
My response to Jerry was to inform him that his duty cycle comment was in error.
So yes, you are correct in regards to the original question being about the ARB airing up tires. I'm glad to see we are all in agreement on that.
As to the PDF you listed, I've no idea what the model # is.
I'll be happy to forward you the e-mail from ARB Australia indicating it is rated at 100% duty cycle. If the company has since changed the duty cycle rating...well, they can certainly do that. It's their compressor and their specs. My last contact with them was July, 2005.....things could have changed since then.
Stu Olson
ARB Locked & Loaded
post #11 of 12 Old 11-25-2006, 07:21 PM
yellj
Stu, just adding info I have, as you have done for many readers, not trying to be a smart arse, just have some personal experience with this one and the orginal documentation, which states should only be used for lockers and not filling tires. I have no doubt that is what ARB told you, in fact I have trusted your word and your write ups implicitly in building my Jeep. FWIW the mini is the top model, again not trying to be combative. Also found the video of it working under water.
http://www.rustysoffroad.com/Merchan...arb/CKSA12.MOV
yellj is offline
post #12 of 12 Old 11-25-2006, 08:57 PM
Stu Olson
Stu Olson's Avatar
Understood.....I'm not sure why the numbers have changed.
Speaking of under water.....this was sent to me by an engineering supervisor at ARB Australia. He hinted that there may be a big brother to this one coming out at some time in the future. I need to find out if that is ever going to happen or not.
Stu Olson
ARB Locked & Loaded
Why not a SCUBA Tank for tire inflation? medcop JK Wrangler Technical Forum 40 08-01-2013 12:49 AM
correct tire inflation? Frozenwalkway TJ Wrangler Technical Forum 10 07-31-2009 04:18 PM
Proper Tire Inflation Dines TJ Wrangler Technical Forum 10 03-23-2009 03:31 PM
Proper Tire Inflation Pressure Bogus1 TJ Wrangler Technical Forum 4 06-29-2008 07:07 PM
Rubicon Tire Inflation, Valve Stems and more ssi dawgfan TJ Wrangler Technical Forum 31 07-25-2007 09:15 AM
