Quantcast ARB leaking...from breather tube? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > ARB leaking...from breather tube?
Old 05-30-2009, 03:02 PM   #1
Apex
Recon death squad
Apex's Avatar
Like the title states. When I hit the switch to activate the locker air starts hissing out of the diff breather tube.
Does this mean it's leaking in the diff? What could it be?
SOLDSilver 02 TJ Apex Edition. "Pandora"
3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff
IndyORV
Apex is offline   Reply With Quote
Old 05-30-2009, 04:19 PM   #2
J-Mox
I think I see a line...
J-Mox's Avatar
I think it means the o-ring in the locker is bad. It's pumping air into your axle. Does the compressor run often or cycle frequently? Mine squirts oil out of the solenoid sometimes after it's been used and I've been told the o-ring is leaking also.
2004 Wrangler X, 6-cylinder, 5-speed, Dana 30 w/ARB, Alloy USA front shafts, Dana 35, 2" BB, 1" BL, OME shocks, Brown Dog MML, UCF Ultra High-Clearance Skid, Lo-Pro Mount, SYE, Pro Comp Adj. Control Arms, Savvy Gas Tank skid, JKS Quick Disconnects, Rock Hard Sliders, 31" BF Goodrich KM2's on Ravine wheels, Hard Top, Bestop Soft-top, Bestop Safari Top
2010 Moab Trip Thread with JeepForum Members
http://www.jeepforum.com/forum/f95/idaho-jeep-moab-2010-a-1038859/
J-Mox is offline   Reply With Quote
Old 05-30-2009, 04:22 PM   #3
Apex
Recon death squad
Apex's Avatar
No the compressor doesn't cycle hardly at all until I activate the locker. Then it doesn't stop running...
IndyORV
Old 05-30-2009, 04:28 PM   #4
Knuckelhead
Knuckelhead's Avatar
Bad seal in the ARB locker...
Originally Posted by Yucca-man View Post
My experience is that poly loves to groan
Knuckelhead is offline   Reply With Quote
Old 05-30-2009, 04:30 PM   #5
J-Mox
J-Mox's Avatar
Cause it's constantly pumping the air out the o-ring into the case. What sucks is that I'm pretty sure the locker has to be removed to replace itBig bucks in labor for a cheap part.
Old 05-30-2009, 04:49 PM   #6
robncar
There are a few places that could be leaking:
1. The two seal housing o-rings that the seal housing assembly rides on.
To replace them, one must remove the carrier.
2. A crack or abrasion of the seal housing copper tube. To replace the seal housing copper tube (attached to seal housing), you must remove the carrier. As long as you're in there, you might as well replace the two seal housing o-rings.
3. The o-ring that is at the housing bulkhead where the seal housing copper tube connects to the incoming air line at the bulkhead fitting. This is an easy repair but you must open the diff to give support to the seal housing tube as you install the new bulkhead o-ring and tighten the center compression nut.
The number 3 scenario is what I'm doing this weekend as the original installer pinched both front and rear o-rings in the bulkhead fittings and I'm starting to get leaks and continuous compressor running and no locker actuation. When you install the new bulkhead o-rings, the center compression nut DOES NOT need to be tight, just snug. When you over tighten the center compression nut you pinch the o-rings.
DON'T FEAR THE RE-GEAR!!!
______
|_____|
(O|||||||O)
|______|
[]===o==[]
RED JEEP CLUB MEMBER #430
robncar is offline   Reply With Quote
Old 05-30-2009, 05:17 PM   #7
Cowboy1629
Stu has an O-Ring replacement writeup on his website, http://www.stu-offroad.com/axle/arb/arb-9.htm
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
...IndyORV...
Cowboy1629 is offline   Reply With Quote
Old 05-30-2009, 06:03 PM   #8
Apex
Recon death squad
Apex's Avatar
Well I just had this installed about a month ago or so. Should I call the guy who installed it and have him redo it? How would you go about it?
IndyORV
Old 05-30-2009, 06:17 PM   #9
Knuckelhead
That's what I would do...
Old 05-30-2009, 09:38 PM   #10
Apex
Recon death squad
Apex's Avatar
I'll make the call on Monday. Thanks fellas
IndyORV
Old 05-31-2009, 09:09 AM   #11
robncar
Update to post #6...
In my case, the leak was indeed the bulkhead fittings. The installer had pinched the o-rings, both front and rear, by overtightening. Also, the copper tube had "slipped" down in the rear due to the o-ring not gripping it correctly. This "fix" cost $18 for gear lube, $1 for o-rings, and a couple of hours work.
Hope yours is this simple!
______
|_____|
(O|||||||O)
|______|
[]===o==[]
Old 05-31-2009, 09:34 AM   #12
Knuckelhead
You could also do a search on ARB D44 drainback...
Old 05-31-2009, 10:28 AM   #13
robncar
I understand the drainback issue but how is it related to an air leak and compressor cycling?
______
|_____|
(O|||||||O)
|______|
[]===o==[]
Old 05-31-2009, 02:53 PM   #14
Knuckelhead
Oops, wrong thread...
Old 06-01-2009, 12:38 PM   #15
Apex
Recon death squad
Apex's Avatar
Well I hope it's that simple...but I did call the original installer and will be dropping the jeep off at his shop tomorrow morning. Hopefully it'll be that easy.
Thanks guys for all your help
IndyORV
Glock Forum
