ARB Compressor Power Source / Wiper Motor Power Wire Color? - JeepForum.com
post #1 of 5 Old 06-27-2008, 09:26 PM Thread Starter
Lawdodge
Lawdodge's Avatar
So I have installed the switches, the compressor and the wiring harness for my ARB's, but I'm not sure where to tap in for the power to the compressor. The manual states to find a 15 amp ignition/acc power wire and tap into it. I had planned on just straight wiring to my aux fuse block, but it's constant hot.
The next thought was to use the windshield wiper motor power wire. It's fused at 25 amps, ignition on, and doesn't get used much. Question is what color and where is that wire located?
Anyone have a wiring diagram for a 2004 LJ that could tell me, or give me a better power source to use.
Thx
Mine - 2004 Unlimited Red 5.7L HEMI, NV241 4:1, RE 5.5" Long Arm, 35's on Champion Beadlocks, MetalCloak fenders and front bumper, Hanson rear bumper, 4.88's, ARB's, Alloy 33 spline D44 shafts, HP44 hybrid front w/ WJ outers, D44 rear ... and to much more .
RED JEEP CLUB #436
Lawdodge is offline
post #2 of 5 Old 06-28-2008, 12:26 AM
Bandicoot
I used the cig lighter wiring for mine...
Bandicoot is offline
post #3 of 5 Old 06-28-2008, 01:46 AM
XXRider
Run the power from your Aux box to a relay. Use something that comes on with Ign(stereo, windshield wiper, head light, etc.) to turn on the relay when you turn the key on.
When you turn on the key your air compressor would get power, when turned off the relay turns off compressor. There isn't anything inside the jeep I'd wire my compressor direct into.
XXRider is offline
post #4 of 5 Old 06-28-2008, 02:18 AM
BoKnows
BoKnows's Avatar
I used the ignition/acc power wire they recommend, right behind the ignition switch there is a bundle of wires. Took out my handy voltimeter, cheapo one that looks like a screwdriver handle that lights up. Poked wires until I found one that lit up when accesories were on (first click of the key, radio on but not engine) and went off when the key was turned off. Then I just spliced into it. Took me 5 minutes and I am no electrcian by any means. 2 years later, no eletrical fires yet!
1997 TJ White
3speed auto, RE Long Arm with ACOS...5" of lift, 35x12.50 PC XAT on 15x8 wheels, Bilstein 5100 shocks, rubicon D44 with front and rear ARBs, AA SYE, Coast CV Driveshaft, 4.10 gearing, ORO Swayloc, ARB Snorkel and K&N filter, magnaflow exhaust, Fabtech front bumper, LoD Xpedition Rear bumper, LoD Rocker Guards, hella lights, 6" Xenon flares, HULA GIRL on dash...........she makes me smile
BoKnows is offline
post #5 of 5 Old 06-28-2008, 10:42 AM Thread Starter
Lawdodge
Lawdodge's Avatar
That's what I'll think I'm going to do. I just didn't like the idea of powering my compressor off a factory curcuit.
Thanks for the info.
RED JEEP CLUB #436
Lawdodge is offline
Fuel Pump Power Wire Color/Location for Kill Switch? spaceboy YJ Wrangler Technical Forum 9 09-11-2012 04:36 PM
Power source for KC Lights williamsmithaud TJ Wrangler Technical Forum 3 09-05-2008 08:00 AM
CB Radio Power Source scrogg JK Wrangler Technical Forum 1 10-03-2007 01:28 AM
Switched Power Source ErikAtTheW TJ Wrangler Technical Forum 2 08-31-2005 08:01 AM
New wiper motor has different color wiring itchyandscratch TJ Wrangler Technical Forum 6 01-16-2005 01:02 PM
