ARB air recommendations - JeepForum.com
post #1 of 48 Old 10-21-2010, 08:51 AM Thread Starter
93ZJ_5.2_ca
I have decided to go ahead with my front and rear ARB set up after weeks of debate. I have had no luck with rancho air lines and leaking airbags in the past. I was really attracted to the Eaton e-lockers but Northridge 4X4 really pushed for the ARB so the next decision is the air source.
I really like the idea of an on board tank and the ability to fill tires and run a few tools in an emergency. Has anyone done this effectively without leaks? Is there a solution to do this for under $300? What regulators are you using that work for the ARB?
93ZJ_5.2_ca is offline
post #2 of 48 Old 10-21-2010, 09:07 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Done properly with teflon tape in the joints, you'll have no air leaks. Don't let anyone talk you into ARB's heavier-duty air lines, you need to stick with the standard air lines. Even ARB advises against the heavy-duty air lines and says to use the standard air lines for reasons explained in their FAQ... basically to avoid damaging hard or impossible to repair while on the trail. The standard duty air lines will just snap if they get snagged, producing a break that can be repaired in ten seconds with their splice-repair kit, not so with their heavier duty air lines that will rip out other fittings if they get snagged. But just properly routing the air lines will prevent this theoretical issue.
Leak-wise, I had a York compressor-based OBA system that was more complex and had more lines & fittings than an ARB air system has and it would hold air for literally (!) months. Proper assembly and installation will assure a leak-free system.
I'm not sure if you're planning to use the ARB compressor but here's a good working schematic for if you are considering other sources of air.
Jerry Bransford is online now
post #3 of 48 Old 10-21-2010, 09:08 AM
dendrophobe
Personally, I'd go with a separate OBA system like VIAIR to run tools and fill tires, and get a dedicated compressor for the lockers - the one ARB sells is ideal for this purpose, as it's made to integrate with the lockers. They also have the heavy duty version, which can fill tires as well.
2005 TJ Sport, Light Khaki Metallic
RE 3.5" coils, OME shocks, Currie control arms, JKS track bars, JKS 1.25 BL, JKS 1 BMML, 35x12.5x15 Goodyear MT/Rs, American Racing ATX Chamber (Teflon), JB Conversions SS SYE, Tom Woods driveshaft, Savvy Gas Tank Skid, Warn 9.5ti, Viking synthetic winchline w/safety thimble, Metalcloak bumper, Metalcloak steering box skid, Savvy rear bumper, HP30 w/Aussie Locker, Barnett cover, XRF ball joints, Savvy tie rod flip, mini-skids, housing end JJ's, , Currie Steering, OME steering stabiliser, Metalcloak Tube Fenders/rear flares/rocker guards, ORO SwayLOC, Banks Stinger Exhaust, Cobra 75 WX ST with Wilson Silver Load, S-POD, Alpine/MOPAR RB1 Navigation Unit w/MOPAR iPod integration, Superlift Truspeed speedo correction, Lightforce 140 Lance driving lights, OTRATTW switch panel, Tinted UPOL Raptor Liner, Savvy Black Magic brakes, Centric rotors, Superior Evo rear shafts
In the garage: Viking Offroad 350 series Hawse fairlead, ARB compressor, Savvy corner guards, Novak 231 cable shifter, EBC green stuff/Centric rotors (rear), Savvy tub rails, Savvy taillights
dendrophobe is offline
post #4 of 48 Old 10-21-2010, 09:13 AM
Jerry Bransford
Administrator
That's the best advice right there, I meant to include that above. Keeping your air sources for the ARB lockers and refilling your tires completely separate is the best way to keep everything as reliable as possible.
post #5 of 48 Old 10-21-2010, 09:15 AM
breckboarder55
I went through a similar process, only I was interested in OX lockers. After speaking with a few vendors, they definitely convinced me that ARBs are the way.
Yes, there are many people running OBA set ups.
I suggest you look into a york style compressor. They move enough air to run air tools, fill up tires (fast), etc. ::Kilby Enterprises::
There is always Viair: VIAIR Corporation - 12 & 24 Volt Air Compressors
You can piece together kits, run C02 tanks, you just about have endless options.
Just do a search for "On Board Air" or OBA
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #6 of 48 Old 10-21-2010, 09:29 AM Thread Starter
93ZJ_5.2_ca
Thanks guys, JB looks like you put many hours of thought in to that system.
I may just go with the $130 ARB system and forget about it and in time build a tank system that if it leaks a bit there is no harm.
WOW I wish I recived this much help so quickly with my gear patterns a few weeks ago.
post #7 of 48 Old 10-21-2010, 09:34 AM
Jerry Bransford
Administrator
I did, I am just thoroughly exhausted from the work it took. Blood, sweat, and tears. I must have spent all of 15-20 seconds finding that schematic in my bookmarks I copied from someone else years ago and posting it up for you.
post #8 of 48 Old 10-21-2010, 09:41 AM Thread Starter
93ZJ_5.2_ca
How long will these ARB o-rings last? Are these something I will need to replace or service every few years, I know keeping rubber parts hydrated is key. I was told to use some vasaline on the rubber o-rings before I install. Can someone back that claim?
post #9 of 48 Old 10-21-2010, 09:43 AM
Jerry Bransford
Administrator
I'm not 100% sure but I believe that Vaseline, a petroleum-based lubricant, will attack the type of rubber used for those o-rings. I would use nothing more exotic than a common silicone o-ring lube.
post #10 of 48 Old 10-21-2010, 09:50 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Get the mini compressor. Install it and forget it. Once you discover the simplicity that ARB delivers to you in the form of their plug and play harness and easy to run and connect air lines, you will be kicking yourself for ever considering any other option for activating the lockers.
Another bit of advice- It's great to plan for emergencies and use that to justify all manner of things you can bolt on, carry around and stack into your rig. After a few years of doing so, you will wake up one day and figure out that all that crap you're doing for emergencies pretty much becomes a self fulfilling prophecy because all the weight you add transforms your rig into a lumbering beast on the trail and highway.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #11 of 48 Old 10-21-2010, 12:52 PM
hatfield44
Vaseline will most definitely decompose o-rings. Dow 33 is good to use on o-rings, or any form of lubricant designed for high end paintball markers.
Also go easy on the teflon tape or use blue loctite on the connections. Little pieces of teflon tape can wreak havoc on a solenoid.
hatfield44 is offline
post #12 of 48 Old 10-21-2010, 05:19 PM Thread Starter
93ZJ_5.2_ca
Thanks all ordered the ARB for the Dana 30 HP + the 30spline axles, also the ARB for the rear Dana 44 and decided on the small ARB compressor kit. Im sure there will be questions to come, my nights will be busy.
post #13 of 48 Old 10-21-2010, 05:24 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
The Puma works well for my ARB's, tools and tires...
Knuckelhead is offline
post #14 of 48 Old 10-21-2010, 05:43 PM
Robert J. yates
Yah that would work but then I guess you're the type that likes listening to the sound of your compressor inside your rig.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #15 of 48 Old 10-21-2010, 06:29 PM
Knuckelhead
AFSOC Retired
I can run a full day on the trail with Puma tank supplying air to the ARB's without the compressor kicking on. When it is running, it's 65 db...
air , arb , install , tank
Amp recommendations Tulloh YJ Wrangler Technical Forum 2 01-09-2008 10:54 AM
Recommendations three3fitty YJ Wrangler Technical Forum 5 09-12-2007 11:49 PM
Oil Recommendations: MCTampa YJ Wrangler Technical Forum 20 12-20-2006 08:33 PM
Recommendations? Notrightfly TJ Wrangler Technical Forum 2 08-07-2005 06:54 AM
Any recommendations? mikey21 TJ Wrangler Technical Forum 2 03-03-2004 06:04 PM
