ARB Air Locker vs Eaton E-Locker vs. OX Cable Locker??? - JeepForum.com
post #1 of 27 Old 04-10-2015, 04:31 PM Thread Starter
evan6353
So I am looking to bump up the my game in my jeep this spring to prepare for some trails this summer. I am going to be swapping in some 5.13 gears front and back (D30 front/D44 rear) to help my 4.0 auto push my 35s along the way.
Now, the question I have is..... which locker should I decide to with?!?!
ARB Air Lockers - seem great but seem overpriced in the world of lockers especially when throw in the air compressor and finding a mounting location.
Eaton E-lockers - Seem to be great as well with a lower cost to them. Plus I feel if something were to happen to the wiring it could be repaired trailer side pretty easily, where if you get a hole in an air line you could be up S$%# Creek without a paddle...
OX Lockers - Also seem quality and one of the more reliable as far as it engaging and staying engaged...
Auburn ECTED - another e-locker that I have seen around but doesn't see to get the "hype" like Eaton does.
I am curious to hear about peoples likes/dislikes, experiences you've had or seen others have with the products.
evan6353 is offline
post #2 of 27 Old 04-10-2015, 04:38 PM
joe_jeep
The arb and ox are both very strong.
The ox cover is not small, big diff covers can have clearance issues for some people.
Early auburns and eatons had reliability issues. They might be better now?
If it was mine I would consider a detroit rear and arb front. Jmho.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #3 of 27 Old 04-10-2015, 04:40 PM
Bigev
When you purchase a ARB locker from 4wd.com it comes with a ARB compressor $170.00 value.
Fwiw.
Evan
KCCO
Bigev is offline
post #4 of 27 Old 04-10-2015, 04:42 PM
biffgnar
biffgnar's Avatar
Fwiw.
Evan
Is 4wd.com doing that year round? ARB runs that promotion once or twice a year for a few weeks.
OP, carrying extra air hose and running it is an easy thing to do if necessary, although I've never had to do it (ARBs front and rear).
biffgnar is online now
post #5 of 27 Old 04-10-2015, 04:42 PM Thread Starter
evan6353
Detroit Tru-trac or Detroit Lockers? I have seen both in my searches...
How do they engage/disengage?
Should mention this will be a freeway jeep as well.
evan6353 is offline
post #6 of 27 Old 04-10-2015, 04:43 PM
biffgnar
biffgnar's Avatar
Auto lockers are not selectable.
post #7 of 27 Old 04-10-2015, 04:51 PM
Bigev
Originally Posted by biffgnar
Is 4wd.com doing that year round? ARB runs that promotion once or twice a year for a few weeks. OP, carrying extra air hose and running it is an easy thing to do if necessary, although I've never had to do it (ARBs front and rear).
Not sure, just added an ARB locker to my cart today and it popped in there saying "free"
No complaints here!
KCCO
Bigev is offline
post #8 of 27 Old 04-10-2015, 05:01 PM
Js139
I'm running and ARB in the front and ected locker in the back. I love the setup. I've had no issues with either and have been highly impressed with the Auburn in the back. That being said, I do have friends that had early versions like mine that had problems. Mine has been worry free though.
You need a selectable for the front unless you have hubs (which I am doubting you do), so that leaves you with the ARB, OX, or Eaton E Locker. Personally, I'd go with the ARB. They are tops on the market. I wouldn't worry about hurting the air line. It is durable and you did some serious work to damage it. Just make sure you run it where it doesn't rub and call it a day. For the rear, you could go anyway. Personally, if I was to build again, i'd go with a full time Detroit in the back. The clicking you get on the roads isn't bad and wouldn't bother me in a DD. They are super reliable and just not alot to go wrong with them (actuators, air/electrical lines/clutches).
I think you'll like the gear choice as well.
Built 97 TJ with WAY too much $ into it...
Js139 is offline
post #9 of 27 Old 04-10-2015, 05:09 PM
biffgnar
biffgnar's Avatar
Only need hubs with auto locker if you want it unlocked in 4WD. In 2WD not an issue.
post #10 of 27 Old 04-10-2015, 05:18 PM Thread Starter
evan6353
Are both styles of Detroits Auto Lockers?
No complaints here!
that is awesome I will have to see if they will count the ARB in a completed axle set-up as the second locker to qualify for the heady-duty compressor
evan6353 is offline
post #11 of 27 Old 04-10-2015, 05:19 PM
biffgnar
biffgnar's Avatar
One is an LSD and one is a locker.
post #12 of 27 Old 04-10-2015, 05:25 PM
kahunabob
Have you checked out Yukon air lockers? I am running them on the front and rear. And a lot cheaper! Robert at RWK Haus did the install with the regear. Great value.
kahunabob is offline
post #13 of 27 Old 04-10-2015, 05:34 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Is 4wd.com doing that year round? ARB runs that promotion once or twice a year for a few weeks...
Its an ARB promo that is going on right now until June 15th.
http://blog.arbusa.com/
Wheelin98TJ is offline
post #14 of 27 Old 04-10-2015, 05:39 PM
Js139
You still get binding in the front end in 2 wheel drive with a full time locker. I can only imagine this is worse on pavement than on the trails.
Js139 is offline
post #15 of 27 Old 04-10-2015, 05:40 PM
Js139
Let me rephrase that, in the TJ's you do when the hubs are always engaged. If he has a spin kit, it is a non event since he can take the front end out.
Js139 is offline
