arb air locker relay needed - JeepForum.com
post #1 of 1 Old 08-08-2010, 11:52 PM Thread Starter
mshrmhd
went to a concert a couple weeks ago and it was a nice day out so i left the top off.. turns out brad paisley wanted water for his h20 tour... by the time we got back to the car i had about 4 inches of water on the floorboards... long story short, the relay was kind of underwater.. next day when i removed the carpet and shop vac'd the rest of the water out then waxed the floor the relay started sizzling then blew the case off... no idea why it waited till the next day to do that though..
so i need to get a replacement relay... no idea if i can get it from autozone or anything or even where i might be able to order it... but when i searched for it, i found this thread..
it is a proquip P1512XP
12VDC 40A
5 pin dual 87 with bracket
has these markings except instead of the resistor rectangle it is, i believe, a diac..
http://www.proquip.com.au/Images/Aut.../Relay%20A.jpg
if anyone can lead me into the right direction, it would be appreciated... thank you.
and also, i have a relay socket for my off road lights that got corroded pretty bad (unrelated) and needs to be replaced.. are they universal? as long as i get a 4 or socket and wire it correctly ( don remember if the lights relay was 4 or 5.. )
Pro Quip*Relays
mshrmhd is offline
arb , air locker , relay , replacement , replace
H4 relay harness problem, help needed NJHCx4xLIFE TJ Wrangler Technical Forum 10 01-30-2009 01:38 PM
Locker relay bypass Poor Boy JK Wrangler Technical Forum 2 05-05-2008 07:20 AM
Headlight upgrade problem relay relay relay rallynut88 YJ Wrangler Technical Forum 8 04-21-2008 09:31 PM
Locker Advice needed... Big Yellow Jeep TJ Wrangler Technical Forum 35 10-24-2006 08:21 AM
Which Locker for Snow? Input Needed Scoobert TJ Wrangler Technical Forum 3 09-28-2005 01:31 AM
