APP985 or AP985 plugs for an 03' TJ? - JeepForum.com
post #1 of 38 Old 06-07-2013, 08:12 AM Thread Starter
jmreagan
jmreagan's Avatar
The question is in the title. I'm doing a tune up and brake job this weekend on my 03' TJ. Which plugs shoud I use, the single tip platinum (AP985), or the double tip platinum (APP985)? The 03' has the coil rail pack, NOT plug wires.
Thanks
-JM
03' Sport, 4.0L, 3.73, 5 speed, D44/D30, 3 inch coil/shock lift, RE track bar, Tera disco's, 35x12.50's Dunlap Mud Rovers MT's, Spidertrax spacers, Viper 5000 alarm, Tuffy console, LOD extreme bumper/tire carrier and front bumper, A-Z rockers, AA SYE, Tom Woods DS, JKS Rear UCA's.
Originally Posted by KKiowaTJ
Sorry master, Dont whips me, I's do betta next time..
jmreagan is offline
post #2 of 38 Old 06-07-2013, 08:18 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
APP985 work best for 00-06'.They will last you 100,000 miles.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 38 Old 06-07-2013, 08:19 AM
Zeep
Either one is a good choice. Pick one based on your budget.
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #4 of 38 Old 06-07-2013, 08:23 AM
JBTJ
No that is incorrect. With the distributorless ignition system he has the APP985 is the correct plug, better yet the XP985 plugs will last twice as long.
The AP985 plugs will work with the older ignition systems that still use a distributer cap, rotor, and wires.
JBTJ is offline
post #5 of 38 Old 06-07-2013, 08:28 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Either one is a good choice. .
No they're not. The AP985 only has platinum on one side of the gap which with the DIS (distributorless ignition system) used on 2000 and newer 4.0L engines will eventually start causing hard to diagnose idle/misfire problems. That is because the 4.0L's DIS fires the plug every stroke and in opposite directions which will eventually cause a plug with different coatings on each side of the gap to fire differently in opposite directions. Between the AP985 and APP985, you must use only the APP985 with 2000 and newer 4.0L engines. It's with 1999 and older 4.0L engines where either can be used. The misfire/bad idle problem became so bad from people using the wrong plug technology that Jeep had to issue a TSB to address the issue. The APP985 has its platinum coating on both sides of the gap so it wears symmetrically with the DIS system's alternating spark directions.
Jerry Bransford is online now
post #6 of 38 Old 06-07-2013, 09:41 AM Thread Starter
jmreagan
jmreagan's Avatar
Thank you BoogieMan, JBTJ, and Jerry. I appreciate your fast responses and for taking the time to explain why I need the APP985's...
jmreagan is offline
post #7 of 38 Old 06-07-2013, 09:49 AM
JBTJ
Or better yet the XP985 Iridium tip plugs.
JBTJ is offline
post #8 of 38 Old 06-07-2013, 09:53 AM Thread Starter
jmreagan
jmreagan's Avatar
I might try those for my next set JB. I just ordered (6) APP985's to my favorite parts store. I know on my wife's V8 4Runner I'll only use Denso Iridium's for that particular engine. They last about 100K...
jmreagan is offline
post #9 of 38 Old 06-07-2013, 09:59 AM
JBTJ
I had just over 80k on mine when I pulled them out for inspection. I could not detect any sign of wear what so ever. I'm going to wait for another 100k to inspect unless I have a reason to do sooner.
JBTJ is offline
post #10 of 38 Old 06-07-2013, 10:21 AM
jeepinhokie
FYI Autolite has a rebate going…
http://www.autolite.com/enmx/node/1124
1.50 off APPs
2.00 off XPs
HOKIES UNITED!
jeepinhokie is offline
post #11 of 38 Old 06-07-2013, 11:06 AM
TheBoogieman
Advance auto and Autolite both have a rebate.Save $3 on each plug for the Autolite Iridium plugs.($1 instant/$2 mail-in)
post #12 of 38 Old 06-07-2013, 11:12 AM
Jeepster83
I change more autolite crap plugs than any other kind of plug. Get the NGK or Champion douple platinum plugs. I drank the kool-aid on the autolite plugs a while back and I threw them away in short order. Misfires and lack of power and lean condition codes. I swapped in some Champion's and all the problems went away. What Jerry said about the double or single platinum is correct, I just disagree whole-heartedly on the brand. You'll end up paying a little more for the MUCH better NGK/Champion/ACDelco plugs but it's more than worth it in my opinion.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #13 of 38 Old 06-07-2013, 11:20 AM
Imped
Imped's Avatar
I've had better luck with the Champion double plat's than with the APP's.
OlllllllO
IndyORV
Imped is offline
post #14 of 38 Old 06-07-2013, 11:30 AM
pmcjeep
Originally Posted by imped
i've had better luck with the champion double plat's than with the app's.
x2
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline
post #15 of 38 Old 06-07-2013, 11:55 AM
TheBoogieman
Eight Jeeps so far with Autolites and never had a problem with any of them.You must have got the defective ones.
