APN Header - JeepForum.com
post #1 of 4 Old 07-19-2010, 08:11 AM Thread Starter
absolutnie
APN Header
I've been having some issues with an exhaust leak after I replaced the cracked OEM header on my Jeep.
I have a pretty noticeable exhaust leak somewhere around cyl #3-5 (assume cyl #1 is closest to radiator). I used the supplied gasket that came with the APN header.
I got frustrated so I took the header off and replaced it with a Felpro gasket, only to find out that the intake port holes don't match the gasket! The box from the gasket specifically says that it is for a 99 TJ Wrangler 4.0. I thought about cutting the gasket but decided to use the APN supplied gasket, with lots of copper gasket sealant. I used the proper torque sequence when bolting down everything.
My question is:
Could the APN gasket be warped?
Has anyone had issues with the APN header not lining up?
absolutnie is offline
post #2 of 4 Old 07-19-2010, 05:45 PM Thread Starter
absolutnie
anyone have any input?
post #3 of 4 Old 10-24-2010, 08:11 AM Thread Starter
absolutnie
fyi - the header was warped. Ended up getting a new one from APN.
Check your headers before you put them on.
post #4 of 4 Old 01-12-2011, 11:22 AM
utah29er
Ah damn! I just found this today.
Just installed my apn header on my '99 cherokee last night. tight fit.
Torqued using their directions.
I have a mondo exhaust leak somewhere, haven't pin-pointed it yet.
I did NOT check if the header was warped
guess I'll pull it off and send it in for replacement.
thanks for the info absolutine
utah29er is offline
exhaust , leak , header , tj , wrangler
Header digizure YJ Wrangler Technical Forum 2 04-12-2010 01:48 PM
4.0 header on 4.2 ??? bjbrowder YJ Wrangler Technical Forum 5 09-16-2009 09:43 AM
TJ header on a 93 YJ Dutchboy YJ Wrangler Technical Forum 1 05-31-2005 07:52 PM
97' 2.5l Header ? orionn TJ Wrangler Technical Forum 27 06-10-2004 05:17 PM
Header or no header? Help! fyrdude TJ Wrangler Technical Forum 2 05-06-2004 12:21 PM
