anyone use Nth Degree Mobility Shock Shifters - JeepForum.com
post #1 of 4 Old 07-18-2008, 01:05 PM Thread Starter
Rafikie
Just curious of the pro/cons and if they're worth the coin
2000 TJ WW build in progress
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #2 of 4 Old 07-18-2008, 01:11 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
is AEV still selling them? i've heard they are awesome if you've got less than stock backspacing and can afford to push the shocks outward.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 4 Old 07-18-2008, 01:20 PM Thread Starter
Rafikie
not sure where to get them, but I did just find this write-up http://www.jeepforum.com/forum/showt...59358&t=407304
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #4 of 4 Old 07-18-2008, 04:37 PM
foreman1063
foreman1063's Avatar
Just be careful if you have questionable downward shock travel. You will lose some travel with the shock shifters. I have RE's 4.5"SF kit with 3.5" springs. After installing the shock shifters I've had to replace two different RE mono tube shocks due to bottoming out and leaking. I finally went to a shorter shock. Just make sure you check it out and add more bump stop if it looks like your shocks may bottom out.
foreman1063 is offline
Nth Degree/AEV Rear shock shifters sduncan TJ Wrangler Technical Forum 5 08-30-2009 10:41 PM
Anyone used this Nth Degree Mobility Oil Pan Skid chouser06 TJ Wrangler Technical Forum 26 05-16-2009 08:45 AM
Nth degree mobility stinger ChadCielencki TJ Wrangler Technical Forum 1 04-03-2007 04:15 PM
Nth Degree Mobility QcJeeper TJ Wrangler Technical Forum 6 02-25-2005 07:55 PM
