anyone tried the clayton stretch kit or a custom stretch setup
#1 | |
how did you like it, hard install? website doesnt provide any info on intstall. im trying decide if i want to get it or try something custom, and to those that tried something different what did you do.
And what major mods are required for it, i know fender and frame modification, relocate gas tank, suspension(obviously) , lengthen driveshaft. Any other major things im missing?
99TJ, 3.5 RE,33x12.5 bfg mts, ford 8.8 and dana 30 with 4.56 gears, rhino lined tub, IPF head lights, AFE cold air intake, TB spacer, catch all floor mats, sound system to block out the loud *** tires, 2 piece hardtop, brown dog 1" mm lift |
#2 |
no one tried it out or stretched there jeep?
#3 |
i have a bunch of people who run the clayton kits.there well worth the money the only good part is were only a few hours away so he welded it all in. but as for a streach the tank has to be moved and new driveshaft. like you said probably shock mounting
90 yj under major construction d70rear,dana60 front,soa,xj rear springs 6"streach,chevy350,700r4,d300,comp cut.more in the works [COLOR=Lime]www.deepwoodsextreme.com[/COLOR] |
#4 |
I will be stretchin my jeep this summer till then....no
Theres no such thing as overkill. Originally Posted by urbanassault And for The sake of humanity, don't pick your nose while driving, if the airbag deploys it will jam your figer up you nose killing you instantly! |
#5 |
Some Call me RockDog
The Nth Stretch kit is amazing. One of the owners of a local shop is putting it on his TJ. they tried to convince me to buy one for mine (good buddy is the other owner) but I went with the standard clayton arms instead.
The Nth kit comes with everything you would possibly need well that's waht they say. 40+ hours for a shop to install. Here's a link to a current JF stretch http://www.jeepforum.com/forum/f9/time-stretch-buildup-thread-348220/
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#6 |
If its from Nth its gonna be top notch definatly one of the highest quality lifts out there one I am proud to sell.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
