Anyone seen a D30 pinion seal fail in 10 miles? - JeepForum.com
post #1 of 9 Old 08-30-2013, 07:45 AM Thread Starter
FleXJ96
2010 JK Wrangler
Wanted to make sure I didn't mess up the seal , so I had a buddy that's a tech and does work on the side at home do it. Wake up this morn and it looks like the seal is toast. Any ideas? My first thoughts are over tightened, breather clogged, or possibly something to do with a bad bearing? All I did was drive it home 10 miles or so... thanks
FleXJ96 is offline
post #2 of 9 Old 08-30-2013, 01:56 PM Thread Starter
FleXJ96
2010 JK Wrangler
dang, no one?
FleXJ96 is offline
post #3 of 9 Old 08-30-2013, 02:01 PM
Imped
Imped's Avatar
Can't say I have.
OlllllllO
IndyORV
Imped is offline
post #4 of 9 Old 08-30-2013, 02:15 PM
Zombi
Could have just been a junk part right from the get-go, who knows.
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #5 of 9 Old 08-30-2013, 07:23 PM
gearswapper
Wow! Never seen this before. I would say something must be on the yoke or inside near your outer pinion bearing. If you think about it that seal sits stationary in the housing. The only contact is very lightly the rubber seal sliding on the yoke. The seal hasn't failed that bad, something is contacting it. I would pull the yoke check it. If it is good I would look at the oil slinger and outer pinion bearing.
gearswapper is offline
post #6 of 9 Old 08-30-2013, 08:54 PM
cj847
I bet you either ordered (or the counter guy gave you) the wrong seal. There were at least two pinion seals used on various year Dana 30's in jeeps and maybe another in broncos.
I don't recall the numbers, but I do recall replacing a "professionally installed" seal after about 3 weeks and noting that the new one did not look like the old one.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #7 of 9 Old 08-30-2013, 09:17 PM Thread Starter
FleXJ96
2010 JK Wrangler
This was a national . Replaced with a Timken today .same thing happened !
Some buddies suggested maybe breather is clogged and its boiling out. And another insist the carrier or pinion is not seated correct after the locker install. It not not start leaking until the locker a few weeks ago. But when I pulled cover almost No fluid came out. I just recently purchased the jeep.
FleXJ96 is offline
post #8 of 9 Old 08-30-2013, 11:11 PM
Boodyrider
Incorrect installation of locker. I suspect incorrect seal as well, if not, then it's runout in the pinion. Who did locker install? Correct sealing after gear work is the responsibility of whoever did the work on the differential.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #9 of 9 Old 09-02-2013, 06:40 PM Thread Starter
FleXJ96
2010 JK Wrangler
i did the locker install, it was not my first and went pretty straight forward. stumped currently. Going to pull pinion and everything . Anyone have a part num er for timken on the correct seal?
FleXJ96 is offline
