Is anyone running Currie 4" springs? - JeepForum.com
post #1 of 5 Old 08-29-2010, 06:15 PM Thread Starter
wzrroc
Is anyone running or know of someone running 4" Currie springs? I need to replace the springs in my TJ and I was wondering if they were any good.
Thanks.
Green 95 YJ. 2.5L Low output. 2.5" RE lift. 1.25" shackles. 33" BFG Mud Terrains.
(SOLD)
Jeep #2: Green '98 TJ 4.0L|AA SYE, Tom Woods shaft|4.88s|3" teraflex lift|2" BB|1.25" BL|1" MML|35" BFG All Terrains|Warn XD9000i|
Daily Driver: 1991 Ford Escort, white w/ graffitti stencils
"I will never understand why people will spend money on huge rims with skinny tires when you can get small rims (15") with huge tires."
"I'm teaching my jeep to roll over, so keep your distance."
wzrroc is offline
post #2 of 5 Old 08-29-2010, 06:32 PM
DBLJ
DBLJ's Avatar
Nope no one.
http://www.jeepforum.com/forum/searc...archid=9051356
With that said, they are one of the better springs out there for that lift height.
DBLJ is offline
post #3 of 5 Old 08-30-2010, 07:05 AM
daveshan
Feeding the money pits
daveshan's Avatar
I've been beating the carp out of them for 3 years, very happy with them.
I picked them because they had a softer spring rate than most of the 4" springs out there (very close to the OME 2.5" HD rate) and I figured they would provide a good on road ride as well as off road. They perform as expected and I'd buy them again in a heartbeat. They gave a true 4" in front and a bit more in back (got the HD rear) and haven't sagged much at all.
Dave Shannon
Durango, CO
Gone but not forgotten
'56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr
daveshan is offline
post #4 of 5 Old 08-31-2010, 07:51 PM
RubiconRazorbac
RubiconRazorbac's Avatar
I've had them on for about 6 months and would definitely buy them again
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #5 of 5 Old 08-31-2010, 08:12 PM
glockster
Mine are in the process of being installed. If you can wait a few weeks I'll get back to you with an answer. I'm replacing RE 3.5" springs.
Marco
glockster is offline
currie , coil , spring , 4"
Newbie Rubi Build -- Currie JJ Lift with AEV 3" Springs AZJeepNewbie TJ Wrangler Technical Forum 173 08-10-2012 10:59 PM
Flex pics needed - Currie A/R with 4.5" RE springs, 10" shocks, RE long arms on 35's. VanBCguy TJ Wrangler Technical Forum 4 04-26-2010 01:55 AM
currie 4" springs or re 4.5s cmc1 TJ Wrangler Technical Forum 1 07-07-2009 06:51 PM
Anyone Running OME 2.5" heavy duty lift springs od BDS 2.5" springs 1992 renagade YJ Wrangler Technical Forum 6 03-31-2009 07:12 AM
Anyone running currie 4" springs? grnsporty TJ Wrangler Technical Forum 3 08-20-2008 06:30 PM
