is anyone running 37's or bigger on dana 44s - JeepForum.com
post #1 of 12 Old 07-03-2007, 04:06 AM Thread Starter
codymparmy
codymparmy's Avatar
im wondering what problems youve had if any. I was thinking about upgrading to dana 60's by dynatrac i have built dana 44's right now and i would like to use the money on a motor swap just looking to here the goods and bads
Living the high life back in the states
2003 Wrangler X With custom dana 44 front and 8.8 rear 4.88 gears detroit rear tru trac front RE 5.5 40 12.50 MTRS walker evans beadlocks LOD bumper rear poision spider trail front
codymparmy is offline
post #2 of 12 Old 07-03-2007, 04:54 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
TJGreg on this forum has the stock Rubicon axles pushing 36s. And I can vouch that he wheels his rig plenty hard. You'll be fine if you have two built 44s.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #3 of 12 Old 07-03-2007, 06:13 AM
cb19950
if you run 37s on some 44s and then do a motor swap they will snap for sure
2000 TJ
When we do right, no one remembers. When we do wrong, no one forgets.
cb19950 is offline
post #4 of 12 Old 07-03-2007, 06:36 AM
JeepNazi101
JeepNazi101's Avatar
That is a pretty bold statement!
What kind of 44's?
Is it a Rubicon 44?
Is it a real 44?
Cromo shafts?
"Professional Driver on a Closed Course"
i has a kool buggy
JeepNazi101 is offline
post #5 of 12 Old 07-03-2007, 06:53 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
A friend of mine runs 38.5" Boggers on D44s.
The rear is a stock Rubi axle and the front is a narowed high pinion from a late 70s Ford.
The Rubi locker has given him some problems but nothing major (air line inside the diff). In the front he blows a hub pretty much everytime we go out but its an easy fix and its a good place to have the weak link. He usually carries 3 or 4 spares.
Oh, this is behind an I6 TJ that has a 75 horse shot of nitrous on it and he runs it pretty hard.
Wheelin98TJ is offline
post #6 of 12 Old 07-04-2007, 06:35 AM Thread Starter
codymparmy
codymparmy's Avatar
hey thanks guys
my dana 44's are built buy alloy usa there not stock i drive an 03 wrangler x but im not going to do the motor swap i thank im going to get it painted and get an atlas thinks guys
post #7 of 12 Old 07-04-2007, 11:02 AM
Metal
Metal's Avatar
D44s will hold 37's just fine. Just drive smart.
04 Unlimited, lifted, locked, 37s, etc.......
Originally Posted by mrblaine
Quit overthinking the lockers. Either get real lockers or forget it, 99 percent of everything else is just mental masturbation for the sake of discussion.
Metal is offline
post #8 of 12 Old 07-04-2007, 11:41 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
a guy in my club runs rubi 44s with chromos and 37s and 5.13s. I run my D30 with chromos and my rear 44 with 36s.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #9 of 12 Old 07-04-2007, 12:00 PM
CCrew
I run 36x13.50 Iroks (measure 36.8") on the Rubi 44's with 5.13's and Alloy F/R axle shafts with no issues. Stock shafts won't live, I wrung a set 1/4 turn at the splines.
Roger
CCrew is offline
post #10 of 12 Old 07-07-2007, 01:40 PM
cb19950
What kind of 44's?
Is it a Rubicon 44?
Is it a real 44?
Cromo shafts?
ya thats true...but if IM doing a motor swap they will snap for sure
2000 TJ
cb19950 is offline
post #11 of 12 Old 07-07-2007, 07:03 PM
freedom5
I'm running 38s with a full detroit and hit the trails alot sence they are just 12mi from my house.
freedom5 is offline
post #12 of 12 Old 07-07-2007, 08:04 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
One thing about some Dana 44 front axles, which includes the Rubicon's front Dana 44, is that they still use the Dana 30's outer knuckles and ball joints. Those particular components are not really up to 37" tires, at least not in the long term.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
Running 35's and bigger on a Dana 30 never monday TJ Wrangler Technical Forum 7 10-16-2009 09:50 PM
Any one running 37's with RC 6" lift RubiExpressTJ TJ Wrangler Technical Forum 18 02-01-2009 11:16 AM
Who's running 37's & what axle width? rdelling TJ Wrangler Technical Forum 5 08-26-2005 08:09 PM
Thinking about trimming and running 37's... Testykalz TJ Wrangler Technical Forum 4 06-02-2005 11:07 PM
Anyone currently running 37's on the YJ Yomie YJ Wrangler Technical Forum 24 01-05-2004 07:41 PM
