Quantcast Anyone with RCI Fuel Cell and PSC TJ Fuel Ring? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Anyone with RCI Fuel Cell and PSC TJ Fuel Ring?
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 04-02-2007, 05:51 PM   #1
HootenTJ
I have a RCI2161A Fuel Cell and installed the Poison Spyder Customs TJ Fuel Ring so I can use my stock fuel pump in my new fuel cell. Only problem is the fuel pump, even when stretched to it's maximum length, doesn't touch the bottom of the fuel cell, there's about 1 3/4 inches it doesn't reach on the bottom(ALOT of gas in my opinion). Anybody have any hints or suggestions on how they've extended the fuel pick-up or fixed this problem?? Thanks
'97 4-Banger, 2.5L, 2" BBL, 4.10 gearing, 33x12.5 ProComp MTs, Custom Flat Fenders, Custom Front Bumper, 2-12" MTX Subs
HootenTJ is offline   Reply With Quote
Old 04-03-2007, 09:56 AM   #2
HootenTJ
bump... Is there anybody out there?
Old 04-03-2007, 11:40 AM   #3
tweba99
That is one problem with the PS fuel cell ring. It raises the pump and makes you loose even more usuable gas. I have the kore4x4customs.com rings which makes is to the pump sits flush with the top of the fuel cell and my pump doesn't hit the bottom of the cell. You DO NOT want your pump extended, as it will come apart since nothing it holding it together. In the stock tank it is almost fully compressed nice and tight so that doesn't happen. You need to put 3 screws (self taping about 1/4" long with rubber washers) in the legs of the pump so you don't have to worry about it coming apart. Here is what I did to mine:
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline   Reply With Quote
Glock Forum
