Anyone ran SEAFOAM in their tj - JeepForum.com
post #1 of 43 Old 02-14-2007, 12:45 PM Thread Starter
jeepsteve
anyone here ran SEAFOAM through their engine? did it restore any power? notice any differences at all?
i was thinking of running a treatment of this stuff and have heard some good things , but want a little more jeep related feedback
Canadian jeep club member 13
2000 TJ Sport 30/35 3:07gearing. 31 bfg allterrains
cobra cb. otherwise pretty stock for now .....
upgrades planned this year... spacer lift, shocks and new rock sliders
jeepsteve is offline
post #2 of 43 Old 02-14-2007, 12:48 PM
azcoyote
azcoyote's Avatar
Anyone search any more?
Just search SEAFOAM....
JEEPLESS... :(
azcoyote is offline
post #3 of 43 Old 02-14-2007, 12:50 PM
ptowntj
ptowntj's Avatar
I don't really have enough miles on mine to run it through...in my opinion...But I ran it through my ranger with 140k on the ticker with no proir treatments and it smoked like crazy...I put it in the fuel,crankcase, and through the intake... It wasn't night and day, but I gained about 16 more miles per tank, like it used to be, and also no more ticking on startup (from putting it in the crankcase). I don't think its a cure, but I think it helps a tired engine out.
8 lug xj.
ptowntj is offline
post #4 of 43 Old 02-14-2007, 01:22 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Seafoam is nothing more than a fad here in JF in my personal opinion. To me, it does nothing special that other less expensive products don't do as well or better. Our fuel injectors rarely need any additional cleaners not already in virtually all gasolines now, and it's not as good as cleaning the throttle body as something made specifically for that purpose is. And for cleaning carbon deposits out of the combustion chambers, you can't beat 12-16 oz. of plain water carefully and slowly trickled into the TB intake with the engine running.
Jerry Bransford is online now
post #5 of 43 Old 02-14-2007, 01:54 PM
bdhaley
bdhaley's Avatar
It works well IMO. I have used it in everything from my jeeps, tractors and my bass boat. You shoulda seen how well it cleaned up the big ole outboard on my bass-boat. I took out one of the spark plugs and the plug was gunked up bad with carbon and other nasty stuff and then I shined the flash light into the cylinder and it looked the same way. I took 2 16oz cans of the sea foam and mixed it with 2 gallons of gas. I drove the boat around on the lake until all of the two gallons were gone. I then pulled the spark plug out and it looked brand new and so did the cylinders too. I love this stuff! There very well may be stuff that works as well and is cheaper but sea foam works great and doesn't break my bank account.
1998 TJ, 4 banger, 5 speed, Rusty's 2" lift, 31" BFG At KO's, AR 15x8
2003 KJ Sport 4x4
bdhaley is offline
post #6 of 43 Old 02-14-2007, 02:00 PM
Agent86
Agent86's Avatar
1948 CJ2A
I tried it. The only thing I was impressed with was the amount of white smoke! I also busted my gut laughing when my wife and kids came out of the house freaked out wondering what was wrong with my Jeep! It was priceless!
I found that running super unleaded about once every four tanks does more for my performance, or if you're in a hurry, about 3 or four consecutive tanks worth of high octane super.
From my experience, Seafoam gets a
Keep in mind, I only have 57K on my Jeep...
Agent86
2002 TJ
1948 CJ2A
Agent86 is offline
post #7 of 43 Old 02-14-2007, 02:02 PM
JoonHoss
2011 JK Wrangler
what in the world would super unleaded do for performance? please explain.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #8 of 43 Old 02-14-2007, 02:03 PM
Jerry Bransford
Administrator
And just exactly what do you think that higher level of octane is doing for you?
post #9 of 43 Old 02-14-2007, 02:05 PM
xxxflhrci
xxxflhrci's Avatar
I'm glad you said that "fad" thing. I've been thinking that every time I see somebody make a post about that stuff and all the miracles it allegedly performs.
You are 100% correct about gasoling having all the injector cleaners that is needed.
Yep, the water misting trick has a hotrodder trick for years. It basically steam cleans the top end. It works great.
xxxflhrci is offline
post #10 of 43 Old 02-14-2007, 02:07 PM
Agent86
Agent86's Avatar
1948 CJ2A
I'm no chemist, so the octane may be doing nothing. All I know is the better gas makes my Jeep run better.
Can't explain it...obviously
Agent86
2002 TJ
1948 CJ2A
Agent86 is offline
post #11 of 43 Old 02-14-2007, 02:07 PM
JoonHoss
2011 JK Wrangler
we just pulled apart a v-6 with a blown head gasket on one side. cylinder and pistons were clean as could be!
Hoss
post #12 of 43 Old 02-14-2007, 02:09 PM
JoonHoss
2011 JK Wrangler
higher octane doesn't make gas 'better', it makes it less resitant to pre-detonation, which isn't an issue with a properly tuned motor with normal compression.
it does make it cost more though...
Hoss
post #13 of 43 Old 02-14-2007, 02:14 PM
Agent86
Agent86's Avatar
1948 CJ2A
Hoss
THAT's what it is! Because it costs more, I think it's better for my Jeep! Why did I think of that.
My kids have used that philosophy for years!
Agent86
2002 TJ
1948 CJ2A
Agent86 is offline
post #14 of 43 Old 02-14-2007, 02:16 PM
Jerry Bransford
Administrator
There is no reason it should make it run better, other than perhaps a placebo effect.
On the contrary, higher octane fuels are harder to ignite than lower octane fuels which means they won't always combust completely in an engine not set up to run that higher octane. The higher the engine's compression, the more octane that is needed to prevent premature combustion. Adding more octane than is needed to prevent premature combustion (pinging/knock) serves no purpose. High octane fuel can actually cause deposits to be left behind in an engine designed for a lower octane.
All octane does is help the fuel resist premature detonation caused by compression within the combustion chamber. That is all octane does, nothing more. A gallon of 87 octane fuel has precisely the same exact energy content that a gallon of 91 octane does.
post #15 of 43 Old 02-14-2007, 02:16 PM
JoonHoss
2011 JK Wrangler
and to think, I thought that philosophy was reserved for spouses...
Hoss
seafoam! bmx_hb_guy YJ Wrangler Technical Forum 0 05-11-2008 09:01 PM
seafoam? bmx_hb_guy YJ Wrangler Technical Forum 4 05-07-2008 08:40 PM
Seafoam chriscisme YJ Wrangler Technical Forum 24 05-05-2008 09:35 PM
Seafoam ????'s 01amberfirewv TJ Wrangler Technical Forum 5 09-01-2006 06:00 PM
seafoam markbento TJ Wrangler Technical Forum 15 08-17-2006 01:00 AM
