Anyone mod the A/C with its own switch? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Anyone mod the A/C with its own switch?
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 08-08-2012, 01:26 AM   #1
shayneox
I would like to be able to turn off A/C but keep fan on and the circulate in cab setting.
All other vehicles I have driven in my life are like that....in the jeep if you switch it to the a/c off mode but with fan it switches to fresh air mode...Thus gets hot faster.
I think Im coming across right with my words..
Any ideas?
shayneox is offline   Reply With Quote
Unread 08-08-2012, 01:41 AM   #2
Necko2529
Necko2529's Avatar
Knucklehead did it. Search his threads and you'll find it.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
Necko2529 is online now   Reply With Quote
Unread 08-08-2012, 02:06 AM   #3
Doubblea
Post up when you find it, sounds like a good idea.
"The beauty of the Second Amendment is that it will not be needed until they try to take it." -Thomas Jefferson
Doubblea is offline   Reply With Quote
Unread 08-08-2012, 05:10 AM   #4
JEK3
JEK3's Avatar
I did mine. Works great. I think I might have used Knucklehead's writeup as inspiration.
JEK3 is online now   Reply With Quote
Unread 08-08-2012, 10:15 AM   #5
Rubi4MyMrs
Tks 4 the upgrade MoodyJP
Rubi4MyMrs's Avatar
It looks like if you put a switch in the light blue/orange wire coming of the 3 wire connector on the mode switch you should be able to keep the compressor off when in the recirculation (or any other) position.
Rubi4MyMrs is offline   Reply With Quote
Unread 08-08-2012, 10:54 AM   #6
IslandTJ
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
Knuckelhead's write up:
http://www.jeepforum.com/forum/f9/be...ml#post7337239
1998 TJ Moss [COLOR=darkgreen][B][SIZE=3]Green[/SIZE][/B][/COLOR] Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
Unread 08-08-2012, 12:45 PM   #7
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by IslandTJ View Post
It also links to this:
http://www.jeepsunlimited.com/forums...2FC+cut+switch
Knuckelhead is offline   Reply With Quote
Unread 08-08-2012, 05:48 PM   #8
shayneox
Sweet , thanks , thats the plan spam.....will hit the hardware store and find a good switch...
So If im reading this right....all Im doing is installing a swith in between one wire...cut the bugger , stick it in between and mount...
sounds to easy...this is gonna help alot....being able to keep the cab air in circulation mode and be able to turn off the A/C and keep fans going...its how it should be done...
Thanks I just checked the site...good info
Unread 08-08-2012, 08:59 PM   #9
Knuckelhead
AFSOC Retired
Originally Posted by shayneox View Post
sounds to easy...
Yep, very easy...
Unread 08-08-2012, 10:46 PM   #10
shayneox
Thanks , am doing this one as soon as I correct my minor wobble , death wooble is to harsh of a term
