Anyone make their Bushwacker Flat Fenders removable? - JeepForum.com
post #1 of 8 Old 06-11-2012, 07:13 PM Thread Starter
CRommel
I'm about to install my Bushwacker Flat Fenders, and decided I wanted to make them removable. Has anyone done this? I was thinking of drilling 6 holes on the top of the fender into the mounting blocks below, and then using U-nuts (like the ones on used to attach the bottom to the blocks).
Anyone do this yet? I can't be the first to think of this.
CRommel is offline
post #2 of 8 Old 06-11-2012, 07:33 PM
kloppk
I just use zip ties to put my flares on.
Cheap, easy, quick!
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 8 Old 06-11-2012, 08:50 PM Thread Starter
CRommel
Are they the Bushwacker flat fenders? Do they flap in the wind when driving at highway speeds? Thanks
CRommel is offline
post #4 of 8 Old 06-12-2012, 01:09 AM
pdangerp
pdangerp's Avatar
I just didn't install the gasket between the flares and the fender. I have removed them occasionally for tight trails, especially when I was learning to drive offroad.
pdangerp is offline
post #5 of 8 Old 06-12-2012, 07:27 AM Thread Starter
CRommel
Great thanks. That what I'm planning to do also, and just wanted to see what others had done.
CRommel is offline
post #6 of 8 Old 06-12-2012, 07:36 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
My bet is you'd soon get real tired of removing and replacing all those screws real quick each time you want to go offroading. You're right to worry about how they'd hold up on the trail, see what happened to mine.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #7 of 8 Old 06-12-2012, 01:16 PM Thread Starter
CRommel
Jerry, thanks. Shouldn't take too long to remove them maybe 5 min. I'm only planning on putting 6 in the top, and I think there are 5-6 on the bottom. What flares are you running? I noticed a different type on your rig in a couple of pictures. I don't do as much wheeling as I want to, so hoping this will work out.
CRommel is offline
post #8 of 8 Old 06-12-2012, 02:28 PM
Jerry Bransford
Administrator
I'm no longer running flares at all.
Getting
Bushwacker Flat fenders on a JKU Roye77 JK Wrangler Technical Forum 16 07-20-2011 10:27 AM
33" tires, bushwacker flat fenders front only ok? Mol JK Wrangler Technical Forum 16 11-02-2010 05:57 PM
Bushwacker Flat Fenders? miahjager TJ Wrangler Technical Forum 4 04-28-2009 01:42 PM
Flat Fenders - Bushwacker or Xenon? PSYCH0 TJ Wrangler Technical Forum 5 03-28-2009 06:42 PM
Hardware to use to make removable Bushwacker flares? only-in-a-yj YJ Wrangler Technical Forum 21 03-02-2008 01:13 PM
