anyone know what's happening? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > anyone know what's happening?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAll Bilstein shocks & struts - Lowest Prices Ever and Ruffstuff Axle Simple Swap Kit!
Unread 02-26-2012, 08:26 PM   #1
MarshallMopar
So I got into my jeep tonight after work it was about 30 degrees out. It was having trouble starting and when it did start the oil pressure wennt to 80 and the engine light came on. Now that its warm it starts fine but the light and oil pressure is still doing it. Any ideas or anyone run into this trouble?
MarshallMopar is offline   Reply With Quote Quick reply to this message
Unread 02-26-2012, 08:47 PM   #2
MarshallMopar
Oh oh yeah it runs fine no spitting and sputtering and oil is good too. Idk why its doing that.
Unread 02-26-2012, 08:50 PM   #3
PlaneJob
oil pressure goes up when it's cold. Oil pressure also goes down when it's hot.
The CEL is an envelope, the scanner is a letter opener, the code is a letter from your lady. If you are going to check the mail you might as well open the letter and see what she has to say...
What code did you get?
PlaneJob is offline   Reply With Quote Quick reply to this message
Unread 02-26-2012, 09:04 PM   #4
MarshallMopar
Haha that's a good one buddy, No obd reader till tomorrow, but I guarantee my oil pressure will be normal and that light will go out tomorrow.
Its done it a couple times, I just wanna know why its actin up. Usually only when its cold.
When its cold the max my op will go is 60. The sensor could be goin. Who knows ! Haha
oil , pressure , starter issue
