Anyone installed an ARB with 5.38 gearing in a Rubicon d44? - JeepForum.com
post #1 of 17 Old 10-23-2013, 08:31 AM Thread Starter
UnlimitedMatt
Just like the title says, I'm looking for some with first hand experience. I have read that it is possible to replace the factory locker with an ARB and that would allow me to use 5.38 gears.
I have a 2005 Unlimited Rubicon and I am currently running the factory lockers with 4.88's. I have the 42rle transmission with 35 inch tires. Between living at this elevation, having heavy armor and having to go up and down hills, I must keep the overdrive off unless I'm going over 50 mph.
My plan is to replace the front factory locker, 4.88's and shafts with an ARB, 5.38's and RCV's. In the rear I will replace the factory locker, 4.88's and shafts with an ARB, 5.38's and a 35 spine shafts.
Has anyone done this yet?
2005 Unlimited Rubicon, Sahara Edition #556, Colorado Jeep Club Member #556
Rusty, if you are reading this, I am still waiting for my $249 refund from 06/2010. Pm me for my address to send the check. Thanks!
UnlimitedMatt is offline
post #2 of 17 Old 10-23-2013, 08:41 AM
Ljcrawler05
I can't assist with your question but just curious if you are going to be installing all of the parts yourself? If I were in your position of spending that much money im pretty sure I'd sell my current rubicon axles that will get you a pretty penny and buy g2s or something comparable so that you have a new set of axles.. the appropriate gear ratio... the lockers you want etc and you can probably get them to leave out the front shafts so you can go to rcvs. This way you can spend about the same money after you sell your current axles as buying new lockers, gears, and shafts for old axles with wheeling and miles on them. Just something to look at...
Ljcrawler05 is offline
post #3 of 17 Old 10-23-2013, 09:51 AM
cjheap
I would probably drop in a v8 instead.
cjheap is offline
post #4 of 17 Old 10-23-2013, 09:59 AM
Af9262
Are those gears going to fit?
Af9262 is offline
post #5 of 17 Old 10-23-2013, 10:09 AM
JeepnBlake
Yes people have done this. There are other rubicon specific forums where all the pertinent info you need about doing this is available.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #6 of 17 Old 10-23-2013, 10:17 AM
rchase559
I bet you will still be using the OD off switch from time to time. I have 5.13s in my TJ and run either 33" or 35" tires depending on how far I'm driving and the conditions of the road. I know it's not exactly what you are going to be running but the gearing is both higher and lower relative to what you want. I still end up using the OD off switch with both sets of tires. The large gap between 3rd and 4th combined with the TCM shifting into 4th very early makes the use of the OD switch needed.
rchase559 is offline
post #7 of 17 Old 10-23-2013, 10:38 AM
cjheap
You can install 5:13s on the stock lockers. You will see little going to 5:38 from there.
You can only do so much with gears. Take the ARB money and put it towards a supercharger or a v8 swap which will address your lack of power at altitude.
cjheap is offline
post #8 of 17 Old 10-23-2013, 10:42 AM
MWV247
You guys here are retarded. Recommending a V8 swap -really. G2 axles Bwa ha ha. This site is becoming a joke.
MWV247 is offline
post #9 of 17 Old 10-23-2013, 10:48 AM
Tonellin
The site is becoming a joke...says the guy who joined last year
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #10 of 17 Old 10-23-2013, 11:03 AM
Ljcrawler05
Didn't say I knew a whole lot about the subject... but I do know how the prices of parts and labor add up because I have a Rubicon myself and have looked into it. Since my argument was based around price and the fact that he is content with dana 44s front and rear.. why am I going to suggest the idea that he needs currie dana 60s front and rear. If g2 is not the brand axle you want use something else.. I believe dynatrac is suppose to be good but like I said I havent personally done numerous expensive axle swaps to test the brands. I was simply making a suggestion that if you are going to pour tons of money into old axle housings and replace everything else why not just sell your current setup with 4.88 gears that people would pay extra for and get a nice set of new axles for virtually the price of just the original parts you were going to buy anyways plus some jeep downtime (depending on your financial situation). Idk maybe it was a stupid suggestion but it is an option if you are going to replace all of that at the same time... anyways good luck with your decision!
post #11 of 17 Old 10-23-2013, 11:06 AM
biffgnar
biffgnar's Avatar
Well, I've been here longer than a year and I tend to agree with him as to this thread at least.
biffgnar is offline
post #12 of 17 Old 10-23-2013, 11:08 AM
biffgnar
biffgnar's Avatar
Your suggestion of considering new axles was a decent one. G2 as the brand is where I'd say things broke down.
biffgnar is offline
post #13 of 17 Old 10-23-2013, 11:11 AM
Ljcrawler05
Duly noted...
post #14 of 17 Old 10-23-2013, 11:37 AM
Tonellin
I'm not disagreeing with him about whether or not he feels JF has gone down hill. I'm just saying he has no scope to make such a broad sweeping comment
It would be like a guy taking one bite out of a granny smith apple and saying "all apples suck!"
06 LJ Rubicon
Tonellin is offline
post #15 of 17 Old 10-23-2013, 11:46 AM
MWV247
Ive been a member for longer than a Year. More like 7 years. My previous user name was Sail78385 but I had some weirdo harassing me over parts I wouldn't sell to him for an unreasonable amount so I had my name changed. Lets do some basic math here guys and say that doing the ARB and 5:38s is a great upgrade. He obviously has the stock lockers and thick cut gears. Changing to a different carrier would give him an advantage there for gears and a great locker to boot.
Dana 60s for 35"s -not necessary
Dyantrac new rear axle is at least 4K -an used rubicon rear axle is worth $1500. This is a garbage suggestion. and lets not enen bring up how much a front axle costs. I guess you could buy the loaded pro rock housing but then again your at a loss with the old housing with no outers or shafts.
like I said garbage especially when he needs a more streetable rig
MWV247 is offline
