anyone have any issues replacing an exhaust manifold - JeepForum.com
post #1 of 10 Old 07-19-2010, 03:54 PM Thread Starter
98_classic
I have a bad crack in my exhaust manifold and I'm planning to buy the cheapo manifold off of ebay and do the job myself.
Anyone run into any problems? My fear is turning 11 year old rusty bolts. Just want to know what to look out for. I have a 4.0L by the way.
Thanks
98 XJ classic - 3" rustys springs, 2" tnt shackle and spacer, RK 3 link longarms, 33 x 12.5 BFG MT's, buncha other stuff. Totaled, will be missed
99 TJ Sahara - 3" FT economy lift, JKS disco's, 33 x 12.50 BFG MT's on silver D-windows, 1" BL/MML, smittybilt tire carrier
98_classic is offline
post #2 of 10 Old 07-19-2010, 05:54 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Thanks
When I did my last manifold all I did was get a mapp gas kit, with the O2 tank, from lowes, home depot etc, and heat the nuts until they were red. Came right off without any breakage.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 10 Old 07-19-2010, 06:38 PM
muddr1
I have a 99 4.0 and when I did mine it wasnt too bad. Although I did have the fender off too. But the bolts came out no problem. Good luck
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #4 of 10 Old 07-25-2011, 07:19 AM
MountainMan864
Anyone got a recommendation how what to replace our manifold with? I gotta get this fixed too and by friday.
MountainMan864 is offline
post #5 of 10 Old 07-25-2011, 08:23 AM
j_niko
2009 JK Wrangler
I just did my entire exhaust from the manifold back two weeks ago. I got the manifold off EBay for about $76, got the downpipe and converter from rockauto.com for about $150 and got the muffler and tailpipe from rockauto for about $140 (plus they have a rebate for $75)
In all it took about 4 hours with two of us.
2000 - Sahara
1997 - Sahara
j_niko is offline
post #6 of 10 Old 07-25-2011, 09:41 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I replaced my 98's exhaust manifold with the Ebay cheapo with accordian joints for $70.It came with the gasket too and worked fine.After that,I bought the Magnaflow direct fit cat with downpipe for $140 and a Flowmaster 40 and tailpipe for $130.
TheBoogieman is offline
post #7 of 10 Old 07-25-2011, 01:25 PM
j_niko
2009 JK Wrangler
Sounds pretty similar except i got the Dynomax muffler (rebate):
2000 - Sahara
1997 - Sahara
j_niko is offline
post #8 of 10 Old 07-25-2011, 01:45 PM
TJeep_1999
2015 JK Wrangler
Had trouble with the #5 exhaust leaking into the #6 intake w/ the cheapo manifold off of ebay. Replaced the provided gasket with on from the dealer and torqued down that bolt first. I think it still has a leak, but not bad enough to cause the check engine light to come back on... Just FYI. Might save yourself having to install it twice by using a OEM gasket.
TJeep_1999 is offline
post #9 of 10 Old 07-25-2011, 02:07 PM
MountainMan864
Anyone got a write-up/how-to to get this done?
post #10 of 10 Old 07-25-2011, 07:55 PM
j_niko
2009 JK Wrangler
j_niko is offline
exhaust manifold , replace , help , advice , rust , TJ
Replacing exhaust manifold, have question. MSJEEP88 TJ Wrangler Technical Forum 8 04-06-2010 06:43 AM
Replacing the Exhaust Manifold on 92YJ mongowo YJ Wrangler Technical Forum 2 01-10-2009 04:52 PM
Issues replacing manifold rustywrangler YJ Wrangler Technical Forum 2 02-09-2006 03:16 PM
replacing exhaust manifold, need tips rick95 YJ Wrangler Technical Forum 4 06-24-2005 10:46 AM
Replacing exhaust manifold gsdpwd TJ Wrangler Technical Forum 6 03-24-2005 06:42 PM
