Quantcast Anyone got a teralow writeup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Anyone got a teralow writeup
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 05-05-2006, 11:12 AM   #1
TJ_with_Tusks
I am taking apart my teralow extreme short shaft and 4:1 kit to redo the RTV seal between the tcase and the 4:1 half. I need a writeup to follow ... thanks.
I got the tcase skid and driveshaft off, but cant get the large nut on the output shaft off. Using a pipe wrench and a impact gun, should I use a cheater bar or something?
04' Columbia TJ
33" BFG AT's, OME HD lift, front airbag suspension, teralow 4:1 kit & supershort shaft kit, TW CV shaft, 4.10 gears, JKS body lift, track bars and quicker disconects, Warn 9.5ti, warn front bumper, garvin wilderness rack, and solid cast aluminum tusks,
TJ_with_Tusks is offline   Reply With Quote
Old 05-05-2006, 11:15 AM   #2
Carpie
Yeah. Go here. Stu-Offroad has a good write up with pictures.
Carpie is offline   Reply With Quote
Old 05-05-2006, 11:22 AM   #3
Jeepin' Rock Cl
I'd try using PB Blaster. Lots of it. That bolt is a tough one once it starts rusting.
Jeepin' Rock Cl is offline   Reply With Quote
Old 05-05-2006, 11:26 AM   #4
TJ_with_Tusks
ha. I actually just read that. Can I get the halves apart by taking out the front driveshaft, then taking the yoke nut off the front?
04' Columbia TJ
Old 05-05-2006, 12:15 PM   #5
TJ_with_Tusks
ok so I got the nut off, and took the tail housing bolts off. Should the tail housing come off, or are there snap rings or what ever ?
04' Columbia TJ
Glock Forum
