Anyone with Currie control arms? - JeepForum.com
post #1 of 6 Old 12-21-2004, 11:40 PM Thread Starter
kpatrick
Trying to get some feedback on Currie's control arms with the Johnny Joints. I am planning on getting some, but would like to get some feedback before I spend the $$$. Performance, maintenance, etc......
3rd time around with 2006 2.4L 6sp, warn bumpers front/rear, clean slate to work with-need ideas....
kpatrick is offline
post #2 of 6 Old 12-22-2004, 12:45 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
They're among the very best, if not the best short control arms. I purchased a full upper and lower arm set and was amazed at their beefiness and quality but ended up getting a "smoking deal" on a RE longarm kit so my Currie arms never got installed.
I'm sorry but for anyone who might ask, the Currie arms I did not install are already sold.
Getting
Jerry Bransford is offline
post #3 of 6 Old 12-22-2004, 07:34 AM
losttj
Currie Arms
Like Jerry said, they are well built. I only have the upper rear adjustable control arms installed. My only complaint is that on my TJ I have to loosen the exhaust up every time I want to grease the right upper arm because I can't get a grease gun on the zirk with the exhause in the way.
losttj is offline
post #4 of 6 Old 12-22-2004, 09:13 AM
Neepers
I put upper & lower Curries on my '99 TJ about 18 months ago and have not had a problem. Combine those with Currie's Anti-Rock sway-bar kit and you will not believe the articulation possible! Ask Santa to bring you a set and you won't be disappointed.
Neepers is offline
post #5 of 6 Old 12-22-2004, 09:58 AM
DanB98TJ
I'm running the Currie arms and they're the best out there, IMHO. They have held up to several years of abuse (they were on StealthTJ's Jeep before mine) and are still in perfect shape...other than lots of rock rash, that is.
losttj - Either turn the bolt around so the grease fitting points to the outside (you can get the grease gun on through the hole in the frame, but it's a pain to get off) or install a 90* grease fitting and point it down.
1998 TJ
4.0/5-speed, D44/HP D30, 4.88s & Detroits, Tera 4:1 and 2-Low, Currie lift, Antirock, 35's
DanB98TJ is offline
post #6 of 6 Old 12-22-2004, 12:26 PM
RUB1CON
RUB1CON's Avatar
how well do the johnny joints hold up in the mud was considering the lift heard alot of good things bout it
'03 Rubicon
RUB1CON is offline
currie control arms question XlostJeepX TJ Wrangler Technical Forum 1 02-12-2010 12:15 PM
Anyone seen or used these? (Currie control arms) remery829 TJ Wrangler Technical Forum 5 12-28-2009 09:38 PM
Currie Control Arms and adjustability ISurvivedNMU TJ Wrangler Technical Forum 16 11-27-2009 12:33 PM
Currie or JKS control arms millhouse1 TJ Wrangler Technical Forum 3 10-13-2007 08:26 PM
Currie control arms crgrissom TJ Wrangler Technical Forum 0 03-17-2007 09:00 AM
