Anybody use Currectlync Tie Rod System with MetalcloaK Chromoly Trackbar - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Anybody use Currectlync Tie Rod System with MetalcloaK Chromoly Trackbar
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEFS: Wranger BRIGHT License Plate LED! Just $3! Great valueKOR Name Your Price Sale
Unread 02-06-2015, 08:52 PM   #1
KozAz
Just like the title says, I assume both would not interfere with each other. But I wanted to see if anyone has installed both.
Note that I will be installing this on a TJ with 2.5 coil lift.
KozAz is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 08:59 PM   #2
Gary2
I have the set up you ask about and have never had an issue . Both are great components. I have about 3" of lift.
Gary2 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 09:18 PM   #3
KozAz
Out of curiosity, did your Currie tie rod have the bend in it to clear the diff? I noticed on their website, the one for the 6in lift had the bend but the other kit did not (At least in their pictures, I will be calling them to clarify)
Unread 02-06-2015, 09:34 PM   #4
Gary2
To the best of my knowledge they are all the same . The TR on all were straight . The draglinks have some curve to it but as I said they all are a like as far as I know
Unread 02-06-2015, 09:46 PM   #5
Cavasar
No Longer DD
Cavasar's Avatar
Currectlync w/ Savvy Tierod
Straight TR
Slight curve
Cavasar's TJ
Cavasar is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 09:48 PM   #6
MurdaJs
That curved part is the draglink
Built one piece at a time, and it cost me many dimes
MurdaJs is online now   Reply With Quote Quick reply to this message
Unread 02-06-2015, 09:56 PM   #7
Gary2
like I said , they are the same on all , straight TR and curved DL. the curve is not as noticeable when looking at it head on when mounted. Your picture showing the curve is from above not head on
Unread 02-07-2015, 12:55 AM   #8
dustymc
Here's one at full stuff on 3.5"
dustymc is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 08:13 AM   #9
Imped
Imped's Avatar
The MC track bar works very nicely with the Currie steering. There's no reason they wouldn't.....
OlllllllO
Float Test Build
IndyORV
Imped is online now   Reply With Quote Quick reply to this message
Unread 02-07-2015, 02:23 PM   #10
jameslee97206
Anyone running the driver side tie rod flipped with the Metalcloak Track bar? I see Cavasar has the tie rod flipped but his Jeep profile says hes using JKS track bar.
jameslee97206 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 02:26 PM   #11
rchase559
See Imped's post. He's ran both together...
rchase559 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2015, 02:30 PM   #12
jameslee97206
I thought he had but i didnt want to spend a week going through his build thread to find a pic.
Unread 02-07-2015, 03:10 PM   #13
Imped
Imped's Avatar
I did. You're worried about nothing.
OlllllllO
Float Test Build
IndyORV
Unread 02-07-2015, 09:31 PM   #14
Shuggs
Imped, how much bumpstop were you running?
Shuggs is online now   Reply With Quote Quick reply to this message
Unread 02-08-2015, 08:02 AM   #15
Imped
Imped's Avatar
As much as required to prevent the track bar and diff cover from kissing.
OlllllllO
Float Test Build
IndyORV
