Any write-ups on how to change alternator on 4.0? - JeepForum.com
post #1 of 17 Old 09-19-2011, 11:13 AM Thread Starter
MountainMan864
My alternator is about to go out, so I need to have it rebuilt. Cant find any writeups on stu olsens website or 4x4xplor. Anyone have a link or care to explain how to do it. Size wrenches needed etc. Where is the bolt tensioner and what size is it. What electrical connections need to be taken off etc. Im gonna clean my terminal posts and cables as well on my battery.
MountainMan864 is offline
post #2 of 17 Old 09-19-2011, 11:26 AM
roundlitefan
roundlitefan's Avatar
I have never changed one in my Jeep...is it that different from any other alternator that it needs a write-up? Not being a smart-***, I just assumed it was bolt, bolt, plug, ground, swap, repeat, tension and tighten?
roundlitefan is offline
post #3 of 17 Old 09-19-2011, 11:27 AM
mike481
mike481's Avatar
First step: DISCONNECT BATTERY
Last step: RECONNECT BATTERY
The rest I'm kind of fuzzy on.
If you want a write-up try checking the FSM
Chuck- A better dog than I could ever deserve
RIP 4-14-2012
mike481 is offline
post #4 of 17 Old 09-19-2011, 11:40 AM
mracoker
I suggest picking up a Haynes auto guide. This is not a difficult task but the guide will give let you know what you need to do.
mracoker is offline
post #5 of 17 Old 09-19-2011, 12:20 PM Thread Starter
MountainMan864
Never had to change one before so its pretty new to me. Just started doing work on my jeep instead of getting ripped off at autoshops.
post #6 of 17 Old 09-19-2011, 12:30 PM
1HouseMouse
I haven't done it in years but, get a quality rebuilt kit. I don't know if there are any good kits anymore. As long as the alternator you are rebuilding it working, it should rebuild just fine knowing that the fields and armature is ok.
Take photos of the exterior case or mark them appropriatly before disasembly. The rest needs to come from experienced folks or an instructional book. The Post Office years back stopped rebuilding their own because of the failure rate was too high as I was told. Stay away from Auto-Bone in case you would rather circumvent the rebuild aspect. NAPA or Rock Auto on line should take care you with confidence. These new alternators that interface with computers Kinda/sorta get creepy when or if they detect something you can't test and the computer picks it up. Just some thoughts.
1HouseMouse is offline
post #7 of 17 Old 09-19-2011, 12:47 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
gawd no. they have just enough information to get you in trouble.
get a Factory Service Manual. if you plan to work on your jeep, you'll need one.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 17 Old 09-19-2011, 12:52 PM Thread Starter
MountainMan864
Eh ill pass. Im tired of putting money in this jeep. I wanna fix this alternator and try to sell it. I need a 4 door. Ill just wing it and get it done. Surprised no one had a website they could send me too.
post #9 of 17 Old 09-19-2011, 01:03 PM
timberwolf0122
Here's my Durango Alternator swap thread, this should help you out.
http://www.jeepforum.com/forum/f9/du...tures-1063518/
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #10 of 17 Old 09-19-2011, 01:38 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
I’m not clear on what you are trying to do & why. What makes you think the alternator is ABOUT to go out? The reason I ask is that short of a bad bearing (noise) I’ve never seen an alternator give advance signs that it is about to fail. There are actually very few parts inside the alternator that can fail short of a major electrical issue that could possibly fry the field or armature windings (never seen that). All you have, really, is a set of brushes, group of diodes (rectifier), & 2 bearings.
With that said, if you do need to remove it, disconnect the battery, remove the belt, remove the 2 bolts, then the 2 wires. I think one wire unplugs, the other has a nut holding it. The belt tensioner is more or less under the alternator (4.0 engine) & is released with a ” square drive ratchet or bar inserted into the square hole. Loosen the tension by pushing the bar to the right & slide the belt off the alternator pulley, then let the tensioner back slowly until it stops. Make sure you have a diagram of the belt routing before removing it in case it comes off some of the other pulleys.
Rubi4MyMrs is online now
post #11 of 17 Old 09-19-2011, 04:21 PM Thread Starter
MountainMan864
My cd player lights kept going on and off. My headlights seemed dimmer. It was also slow to start. Maybe I just need to clean my battery terminals. The battery guage/volt meter guage was reading about on 9 and it usually reads above 14. Then after a second of the jeep running the guage would drop to 0 and my check guages light would come on. Thats why I think my alternator is going on. I took my battery to autozone and they said my battery was fine. So it can only be the alternator right?
post #12 of 17 Old 09-19-2011, 04:26 PM
mg2380
This.
mg2380 is offline
post #13 of 17 Old 09-19-2011, 04:55 PM Thread Starter
MountainMan864
Decent write-up but ill stick to something cheaper and oem. Just gonna have my alternator rebuilt for 60 bucks instead of shelling out twice that.
post #14 of 17 Old 09-19-2011, 06:25 PM
JBTJ
You descibed two different problems in your post. Your problem with slow to start I'd think is your battery, as the alternator hasn't even come into play at this point. But, everything else you described does sound like the alternator or a poor ground. What other problems are you having that makes you want to get rid of it? Alternators go bad no big deal. You can take it off and have it checked as well. Should take you 5 minutes to get it off.
JBTJ is offline
post #15 of 17 Old 09-19-2011, 06:55 PM
mracoker
You are correct, I took your advice and bought a pdf version of the service manual and its way better than Haynes! How did I got this far without? I'm Glad I posted that or I would have never know
I just have to bring my laptop in the garage now and try not to get it too dirty!
mracoker is offline
How-To: BA-10/5 Tranny fluid change write-up. rustywrangler YJ Wrangler Technical Forum 34 10-25-2014 10:47 AM
Write up needed for transmission fluid change billabong266 TJ Wrangler Technical Forum 3 10-13-2009 05:43 PM
Any write ups on how to change the power steering fliud? bill8bud YJ Wrangler Technical Forum 5 09-17-2009 01:01 PM
Write up on Transfer case fluid change??? ((~JEEP~)) TJ Wrangler Technical Forum 10 06-21-2006 11:33 PM
Write up for Front Diff. Seal Change? IPlayInMud TJ Wrangler Technical Forum 1 04-08-2006 06:24 PM
