Any ways to compress a spring other than spring compressors? - JeepForum.com
post #1 of 8 Old 09-02-2009, 08:21 PM Thread Starter
wmeyer116
I only need about 2 or 3 inches. Any ideas? lol autozone is closed unfortunately
Originally Posted by never monday View Post
Marcus,
Leave your inbred childish comments somewhere else. They are not welcome on JF
wmeyer116 is offline
post #2 of 8 Old 09-02-2009, 08:22 PM
Hesher420
?stand on it if you are really fat?
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #3 of 8 Old 09-02-2009, 08:24 PM Thread Starter
wmeyer116
haha... well its the front coil springs. Im doing a 3 inch lift. got the front on jack stands and the tires off. I have the coils up inside the upper coil perch, but just not the bottom one. I need something like 2 inches im thinking
Marcus,
post #4 of 8 Old 09-02-2009, 08:25 PM
Imped
Imped's Avatar
Jack one end of the axle up and put the other side in. You'll have to manhandle it but you should be able to get it in. Make sure your frame is on jack stands before you do this.
OlllllllO
IndyORV
Imped is offline
post #5 of 8 Old 09-02-2009, 08:25 PM
yj35s
is it in the jeep still, if it is I jacked up the axle as far as it will go until the tire comes off the ground just barely. Take a heavy duty chain and put it threw the spring and around the axle just for safety. It will compress the spring enough for what I had to do just a thought.
-1990 Wrangler- 5 inches, 35x12.50, chevy 350, 700R4, line-x tub
-2003 Grand Cherokee- 2''BB and 265/75 BFG all-terrain (daily driver)
yj35s is offline
post #6 of 8 Old 09-02-2009, 08:32 PM
bandit455
i know on my jeep we used three rachet straps
a bottle jack also works great to get as much droop as possible, wedge between the axle an the frame
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #7 of 8 Old 09-02-2009, 08:33 PM
pbj-tj
Disconnect the track bar , that should be all you need to do.. or you can disconnect the upper control arms where they are connected to the frame, they will go in super easy. I put in 4" lift springs without any compressor at all, and it was suprisingly easy
(Building up my 1997 TJ - LS1 V8 Swap and more.. here's my thread)
pbj-tj is offline
post #8 of 8 Old 09-02-2009, 08:36 PM
filo bedo
Disconnect the shock. Then use a big prybar and a healthy kick to pop it in.
filo bedo is offline
can you over compress a coil/spring? rballman JK Wrangler Technical Forum 2 05-10-2009 09:22 PM
Need spring compressors or not? outlawjosywales TJ Wrangler Technical Forum 9 12-06-2008 02:51 AM
Spring Compressors kkiel02 TJ Wrangler Technical Forum 18 06-09-2006 08:25 AM
Spring compressors lostskiier TJ Wrangler Technical Forum 15 08-04-2005 02:14 AM
how much can you compress a spring 4greenjeep TJ Wrangler Technical Forum 1 09-28-2004 12:26 AM
