any way to soften up throttle? - JeepForum.com
post #1 of 13 Old 07-28-2007, 10:52 PM Thread Starter
KI4KWF
its just too touchy. dont mash it, it idles. then, it takes pressure to mash it in. result-very jumpy. when starting off, in about 1st-3rd gears, its hard to make it gradual and steady... makes a huge lunging and throwing everybody around. is something not lubed right here or something? something too tight? im gonna change the oil and trans fluid this coming week, so i can work with it then.
KI4KWF is offline
post #2 of 13 Old 07-28-2007, 11:16 PM
killas1mo
killas1mo's Avatar
check your throttle cable for kinks or rust. You might need a new cable if you cant get lube in it if its rusty.
97 TJ 4.0 5 speed
4.5" RE + 1" BL
33" BFG M/T's (going to 35" tires after 8.8)
Milemarker PE 8000 winch
Aussie in D30, damn D35 out back (8.8 time!)
killas1mo is offline
post #3 of 13 Old 07-28-2007, 11:19 PM
BlkBird
Maybe the cable is pinched or kinked somewhere?
2004 Wrangler X 4.0
2000 Cherokee Sport 4.0
1992 Dakota Sport 5.9
1971 Pontiac Firebird
BlkBird is offline
post #4 of 13 Old 07-29-2007, 01:18 AM
BYuen
BYuen's Avatar
How about some carbon build up maybe, possibly?
BYuen is offline
post #5 of 13 Old 07-29-2007, 01:24 AM
adurbin
Not saying in a negative or degrading way, but could also be a result of driver error, I can drive my TJ like a car. Put my wife behind the wheel and the clutch and It feels like a big rig.
97 TJ
4" Pro Comp Suspension Lift, 1" inch Body Lift, 33x12.50 Mickey Thompson Baja MTZ's on Cragar soft 8s, MileMarker PE8000 Winch, Rockcrawler Bumpers, 8.8 LSD.
Northeast Tennessee Jeep Club Member #1
adurbin is offline
post #6 of 13 Old 07-29-2007, 02:47 AM
afguy
You could swap in a 4cyl and you would never complain about too much power again.
Seriously though, check the area of the pedal that pivots.
98 XJ Sport with 4.5" lift, 31" MTZs, and other goodies.
afguy is offline
post #7 of 13 Old 07-29-2007, 07:33 AM Thread Starter
KI4KWF
hey, i've been feathering pedals since i was 8. if it could be smooth, i would make it. i'll lube the whole steering system up real good this week.
KI4KWF is offline
post #8 of 13 Old 07-29-2007, 08:41 AM
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
Oil or grafite? My wifes cars having the same problem.
Or does it matter?
1948 CJ2a
Airborne4X4 is offline
post #9 of 13 Old 07-29-2007, 12:14 PM
adurbin
My TJ is a 4 popper, keeps up with all you 6 bangers on the trail. Dont punch me in the face just because your the second slowest vehicle on the road
97 TJ
adurbin is offline
post #10 of 13 Old 07-29-2007, 02:46 PM
EvilM0nkey
EvilM0nkey's Avatar
You probably have a carbon buildup around the throttle body. I would just clean it out with some t-body cleaner and an old toothbrush
EvilM0nkey is offline
post #11 of 13 Old 07-29-2007, 03:39 PM
afguy
I too have had a 4cyl (#3 of 5 Jeeps) and while it was great on the trail, I prefer the 6cyl overall. You would also be suprised at how quick a Jeep with 4.0, 5spd,4.56 gears, and 35" tires is. Anyway, back to the topic at hand.
afguy is offline
post #12 of 13 Old 07-29-2007, 05:42 PM Thread Starter
KI4KWF
i'll get me some cleaner when i hit up the store to get engine oil, trans fluid and whatever else i have the impulse to get!
KI4KWF is offline
post #13 of 13 Old 07-29-2007, 10:49 PM
Rule303
I find my TJ throttle way too sensitive also, especially for a 4x4.
Rule303 is offline
best way to soften up ride?? bombadillo YJ Wrangler Technical Forum 15 06-29-2006 02:46 PM
Will new front control arms soften my ride? Roothog TJ Wrangler Technical Forum 13 04-21-2006 10:51 AM
How to soften ride?? itsajeepthing17 YJ Wrangler Technical Forum 1 12-17-2005 01:44 AM
How to soften ride?? itsajeepthing17 YJ Wrangler Technical Forum 20 12-15-2005 01:09 PM
Soften up the ride a bit? nosajmc YJ Wrangler Technical Forum 11 09-15-2003 02:39 PM
