Any Tips?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Any Tips??
Hyline Offroad Louvered Hood Vents, YJ's, TJ's, JK's, CJ'sIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Unread 04-22-2006, 12:31 PM   #1
Muddy Tj Zack
Any Tips??
I just remembered why I hate mud today. Went for a little fun yesterday, got into some mud, overheated and boiled some antifreeze. I cleaned out the radiator fins that were clogged with mud and sprayed the motor off. It's not overheating now but running a little hot (around 220-230) and my oil pressure is pretty eratic (ranging from 0-40 but mostly staying around 20) What did I do? What should I check? My antifreeze is a pretty low so I'm thinking thats why its running a little hot. I'll add some oil hopefully the pressure will go up, but what else should I check. Thanks guys!
'97 Tj Sport, 4.6L Stroker, 5-Speed, 4-in suspension lift, 35" TrXus M/t's, Dana30/Ford 8.8 w/ Aussie Locker, Teraflex ExtremeShort SYE, custom front and rear bumpers, Flowmaster Off-road Series, and a bunch of other goodies........MoPar or No-Car!!!
Muddy Tj Zack is offline   Reply With Quote
Unread 04-22-2006, 01:18 PM   #2
RockRunner85
Oil pressure sending unit is prolly going bad. Don't overfill the engine. Keep it between the add and full.
If the engine is still running hot and you a/c you will want to pull the radiator and clean between it and the a/c condenser.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline   Reply With Quote
Unread 04-22-2006, 01:38 PM   #3
de6w6it
I agree, the oil pressure sender is probably going bad, also, may want to make sure the thermostat is not stuck closed, or partially closed, over heating may have messed it up a little bit.
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:http://www.yotatech.com/f191/de6w6it...-lemon-190657/
de6w6it is offline   Reply With Quote
Unread 04-24-2006, 02:41 PM   #4
Muddy Tj Zack
Thanks for the advice guys. I went ahead and went for a ride today. The temp was fine, in traffic it went to about 220 but most of the time it was at 210. But after a half hour or so into the ride my oil pressure would drop to 0 at idle, and 40 as soon as I started to go. I read up on the oil pressure sender and I guess I should change it since they aint that expensive. But is my motor really not getting pressure or is it just not sending the right pressure to my guage? Can I drive around in stop and go traffic like this? Also were is this part at on my Jeep and how can I change it?
Unread 04-24-2006, 02:45 PM   #5
Jeepin' Rock Cl
It's most likely the sender . You would know if your engine got 0 pressure for any length of time.
Jeepin' Rock Cl is offline   Reply With Quote
