Any negative effects of a TC drop?
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
4Wheelin' dreamin
This summer I plan on getting a Rough Country 3.25 lift kit or somthing of equal height, heres my question becuase this kits would require a TC drop I was wondering if a TC drop put any added stain on the transmission, TC, or any other drivetrain related parts? I don't think it would, but I'm not sure.
Thanks for any help.
#2 |
after puting it on look at you motor mounts if the motor is pulling back on them then losen the trans mount let it slide forward then tighten them back up the only bad part of a tc drop is you pay good $$$$$ for a lift then lose it on the trans pan.
#3 |
If anything the TC drop would take the strain off of your drive components, because it brings the angles closer back to stock after you install the lift. I put this lift on my jeep but excluded the TC drop, because #1 I have a rubicon RC told me I would not need it, and #2 I put it on because I am an inquistive dumb *** and then started getting major drive line vibrations. So I took it off. It literally takes 10 minutes to put in or take out.
#4 |
Exactly, the worst part of a t-case drop is the massive loss of ground clearance.
Visit My Homepage! |
#5 |
It hangs down low.
I am assuming this is the 2.5" suspension and 1.25" Body? You could probably do a motor mount lift and skip the T-case drop.
To Veterans past and present, thank you for your service! 99 Jeep Wrangler-Just another TJ on 33"s55 Dodge Royal Lancer- Resto Project 87 Mazda RX-7 Turbo II-Built. 87 Mazda RX-7 SE-Burn Victim 02 Toyota Celica GT-S-DD/beater |
#6 |
If you get a set of M.O.R.E 1 inch motor mounts which lift engine up 1 inch and do a JKS 1 1/4 body lift you might be able to do away with the TC drop resulting in more ground clearance as to doing a tc drop.
#7 |
A 1" MML most likely wont get rid of all the vibes with 3.25" lifted springs... just so you know.
#8 |
Farm Wheeler
Transfer case drops are nothing but a lawyers' conspiracy. There are hundreds, if not thousands of Jeepers all over the country that have been suckered into buying and installing them. When the catastrophic failures start the lawyers will swoop in with a class action lawsuit and they will make millions and the poor Jeepers will be left with pennies and destroyed Jeeps.
Keep in mind that free advice can frequently be worth less than you pay for it. |
#9 | |
b/c i have a 2002 tj with a 3" full trac and i will pull the drop out and take you for a ride and you tell me if that fixed it lol. i would like to spend the $ for it then spend it on new u-joint and slip shafts.. besides almost every lift comes with them. so no $ out of pocket for it |
#10 |
4Wheelin' dreamin
How would a motor mount lift help the drive angles?, and how hard is it to do?
#11 |
Farm Wheeler
antec - Transfer case drops are included in numerous lift kits, this is a well known fact. TC drops are the subject of numerous discussions on this board and others.
Humor, sarcasm, pulling your leg, joke,… Any of these terms mean anything to you?
#12 |
sorry dont take it as i was jumping at you. there are a lot of people out there with some wierd things that thay "KNOW IS TRUE" lol. and i just like to have the wright info out there lol. there is one guy on here that think a dana 35c is fine with his ls1 and 44" tsl lol. i just like for every one to have the wright info.
#13 | |
this reduces the angles on your ujoints which helps decrease driveline vibes and ujoint failure its only slightly more difficult than replacing the motor mounts this also presents you with the option of installing a body lift which would allow you to raise the transfer case and add clearance below your jeep downside to raising your transfer case is you will likely need a CV drive shaft for the rear its a never ending money spending downward spiral good luck with the plans i have for my jeep, it will end up being an $87000 toy that i dont need ![]() |
#14 |
4Wheelin' dreamin
So is a MML a do-it yourself job or pay a shop to do it?
#15 |
i would do it myself, but its up to your mechanical know how
have you ever changed out motor mounts yourself? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
