Any issues with this as a trailer tie down point? - JeepForum.com
post #1 of 92 Old 06-15-2012, 02:31 PM Thread Starter
ekim
Can anyone see a problem attaching to the axle like this for trailering?
ekim is offline
post #2 of 92 Old 06-15-2012, 02:38 PM
flying_bosun
At least wrap the chain and hook a link. With a shock load that hook could tear away or through that bracket. Not likely, but possible. I'm generally over-cautious with that sort of thing.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3 of 92 Old 06-15-2012, 04:45 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Where is your sway bar?...
Knuckelhead is offline
post #4 of 92 Old 06-15-2012, 08:51 PM Thread Starter
ekim
Above the gas tank. I don't think it's needed for trailering anyway
Also, that mount is aftermarket and pretty Thick and welded solidly. I was mostly concerned about improperly loading the hook.
ekim is offline
post #5 of 92 Old 06-15-2012, 08:58 PM
Knuckelhead
AFSOC Retired
Currie built 9"?
Dont you have something you can setup on the bumper for the chains?...
Edit: Ohhh, I thought you meant pulling a trailer (safety chain)!
Isn't that bracket .125"?...
post #6 of 92 Old 06-15-2012, 09:21 PM
flying_bosun
The cantilever on the hook is not good at all, and the chain link is even worse. I still say just wrap the axle with the chain and attach the hook to the chain as it's intended.
I initially thought the same...
― Ron Paul
post #7 of 92 Old 06-15-2012, 09:41 PM Thread Starter
ekim
I originally was using an axle strap, but the brackets were starting to tear into it. I'll just wrap the chain around the axle. The sway bar bracket is 3/16, but that's moot since I'm not going to use it.
I guess the only way that track bar bracket could be used properly would be to go straight down so there are no abrupt change in direction on the chain?
I don't intend to do that, I just want to make sure I understand what is proper.
ekim is offline
post #8 of 92 Old 06-15-2012, 09:55 PM
flying_bosun
Thinking for another minute, it's one of those things that people may do and get away with all the time, but wrapping it really isn't right either.
A chain should never wrap or break (bend) around anything but a proper corners or edges; their max strength is only in straight line tension.
Can you not get a straight hook onto the CA brackets? If you do use a wrap, which I can't wholeheartedly recommend, pad the tube with something.
― Ron Paul
post #9 of 92 Old 06-15-2012, 11:44 PM
pcoplin
pcoplin's Avatar
Wrapping that chain around the axle (with no pad) is just fine.
pcoplin is offline
post #10 of 92 Old 06-16-2012, 12:56 AM
flying_bosun
....it's one of those things that people may do and get away with all the time, but wrapping it really isn't right either.
Do what you will, but wrapping any corner results in a break over of links just like the one attached to the hook in the op pic. Huge strength loss and virtually no shock resistance compared to direct tension. You'd be very surprised how a towel pad changes the dynamic.
Like I said, I'm kinda a-type about these things.
― Ron Paul
post #11 of 92 Old 06-16-2012, 06:48 AM
wushaw
Rockin jeep
wushaw's Avatar
Since your not using that mount for anything but unusable ballast why not cut it off and smooth the tube out and go back to using a axle strap?
wushaw is offline
post #12 of 92 Old 06-16-2012, 07:12 AM
LJWrangler
X 2 it looks like its seen better days anyway
SILVER JEEP CLUB #71
My Build
LJWrangler is offline
post #13 of 92 Old 06-16-2012, 08:54 AM
pcoplin
pcoplin's Avatar
I've worked as a rigger and yard guy in a crane yard, there's no problem doing it to hold down equipment. That's kind of what the hook is for.
Let me guess, you're an engineer?
pcoplin is offline
post #14 of 92 Old 06-16-2012, 11:23 AM
flying_bosun
Professional rigger with an engineering background, thanks. Chains and hooks are not intended to be cantilevered. I use them on an almost daily basis and like I've said twice already, people do it all the time without consequence, but that doesn't make it right.
― Ron Paul
post #15 of 92 Old 06-16-2012, 12:44 PM
Hillbilly88
2014 JK Wrangler
Look around for some j hooks like what wreckers have on the end of there chains when they hook the axles. Best thing there is being that's what there ment for That's what is use since I worked for a wrecker company and was givin a set when I ask we're I could get some
Hillbilly88 is offline
Affordable racing seats with 5 point or 3 point harness. LiveAndLearn TJ Wrangler Technical Forum 8 04-13-2012 10:42 AM
Trailer wiring harness issues mntbkrguy YJ Wrangler Technical Forum 2 03-26-2012 04:39 PM
TJ develops tracking issues with a trailer OCS12 TJ Wrangler Technical Forum 6 02-20-2011 10:19 PM
2 point or 3 point seat belts?????? Brock1 YJ Wrangler Technical Forum 23 04-09-2010 06:33 AM
Rear Recovery Point Issues!!! muddyfunkster YJ Wrangler Technical Forum 31 02-10-2007 07:54 PM
